Light Over Key Won't Turn Off
Charging battery and noticed key light won't turn off after locking car.may be why new battery was dead..how do you fix that light? is there a relay or switch somewhere? thanks
Is your hood closed? I keep my hood open for powering my maintainer. The hood light and keyhole light will stay on - I push down the latch to make the car think the hood is closed. You just have to make sure you pull the hood lever prior to closing the hood!
Originally Posted by Avenger6
Errrr....? "Light over key?" What are we referring to here? I want to see if I have this and check it's function. Looked around the ignition key location, but don't see anything.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Robin 993DX
Basically it helps you to find the ignition key hole in darkness.
