GB Chip - TEST RESULTS
RL Technical Advisor
Originally Posted by Red rooster
Steve,
Maybe a revisit to the timing calibration will get round this 91 situation ?
That stuff is all we have here so some careful thought about rpm versus detonation limit will pay off.
It would be really interesting to know if any US states have our situation or are we alone with 91 only !
Certainly a crude attempt to raise timing by the same angle right across the rev band , just like a SC distributor swing , is not a good idea !
I am certain that that is not what you are doing.
It will be intruiging to see if ethonal added to fuel will make changes , maybe in the right direction .
All the best
Geoff
All the best
Geoff
The USA is highly unusual in that octane availabilities vary all over the country,...
Some states have 93, some have 92 and some only get 91. Its based on fuel distribution, local altitudes, and state-mandated emissions controls. Combine that with the variations in each engine from accumulated carbon, compression differences, and valve timing, you have cars with varying levels of octane appetites.
All software was developed and tuned on load-type chassis dynos at varying loads and no across-the-board (global) timing changes were made. Each & every load point at different RPMs were individually mapped for fuel and timing and I'm pretty sure you know how labor intensive this process is,......
Technical Guru
Originally Posted by smddanny
what is the abcissa? Degree of what?
Woudl this be retard from full advance as a f(temp)?? If so.. .then only 4.5 degrees up to 134 degrees?
Originally Posted by Steve Weiner-Rennsport Systems
a live re-map is not practical since those values are only valid on that day & at that time.
Originally Posted by JasonAndreas
Wouldn't a live remap allow you to set the timing for mean best torque without any knocking and the start and length of injection based on measured optimum values for each specific engine?
Two issues though:
1) Timing values during remap are valid for that day, fuel load, and atmospheric conditions. Mapped values must be "loose" enough to permit a margin so that the engine will not detonate when its hotter or when one gets an inferior batch of fuel (not uncommon). This was the initial problem with "The Program" aka Unichip. Its a fine line to plot noticable performance gains and enable the car to run on available octanes (including the seasonal variations).
2) Although a live re-map is ideal to be sure, its expensive and impractical to do as I'm sure you can appreciate. Given the time it takes to do that, IMHO, not many people would be willing to shoulder the costs.
Originally Posted by pcar964
Did you develop your own mapping? Or do you choose from the different maps provided by GIAC?
We work with GIAC to develop different software for custom solutions. In short; both.
"Wouldn't a live remap allow you to set the timing for mean best torque without any knocking and the start and length of injection based on measured optimum values for each specific engine?"
Jason, you must be playing "devil's advocate", right?
"Certainly a crude attempt to raise timing by the same angle right across the rev band , just like a SC distributor swing , is not a good idea !"
It should be obvious from the before and after torque curve, i.e. that's what was basically done.
"Mapped values must be "loose" enough to permit a margin so that the engine will not detonate when its hotter or when one gets an inferior batch of fuel (not uncommon)."
Right! And this is what Porsche/Bosch did during product development.
The so-called tuners just narrow this margin which results in detonation.
"Each & every load point at different RPMs were individually mapped for fuel and timing and I'm pretty sure you know how labor intensive this process is,......"
Please!!!!!!!!!!!
1. Modifying the fuel maps has really no effect other that at WOT, i.e. because the ECM operates
closed loop the majority of the time, and at WOT the AFR is very close to ideal anyway.
2. The key result occurs from just tweaking the timing a few degrees, which can be done in
10 minutes (change ignition map) on a PC. Hardly a major effort requiring MAJOR dyno work.
Sounds like more marketing hype! And now that the chip source has beed mentioned,
it's Giac that usually results in the most problematic pinging issues, as those cars are
where the requests come from for replacement stock chips to solve detonation & poor running problems.
Bottom line: The extent of hyperbole never ends to promote a product!
Please!!!!!!!!!!!
Loren:
I'm quite surprised that apparently, you know little about dyno mapping these cars since your comments about "10 minutes on a PC" and "marketing hype", just border the absurd,....
Personally, I think you're a LOT smarter than that, but your obsession about this subject totally clouds your judgement in this area. I cannot respond to your comments any longer on this since you have lost your objectivity, sir.
Steve,
Thanks for that . I began to think the USA had 100 fuel everywhere ! You are certainly right that some motors with a little carbon build up etc can easily become detonation prone .
Mine runs fine on 91 with no det confirmed by a Hammer knock log.
Maybe its a good thing that very few 993s have a real 11 CR. Maybe one day Porsche will get the history book out and go back to the 1970s 2.4 compression like 8:1 !!
Geoff
Geoff
Steve,
Geoff
Geoff
If 993's (and other Porsches) truly had the advertised compression, we would not be able to do much with engine management software, given the sad state of pump gasolines; at least here in the US.
IMHO, CR's will only go higher in the quest for improved fuel efficiencies. The new 997 motors have DFI which affords much better control of fuel atomization and even higher CR's. Thats how they are able to keep boosting HP while maintaining the same displacements,...
