dialing in PSS9
dialing in PSS9
Hi gang,
The tinkering begins. I was just out in the garage and adjusted the Bilstein firmness settings. One question, the dials on the rear shocks did not 'click' like the front ones did. I set them on what appears to be the '4' setting (fronts on '5'). Honestly, I can't tell much of a difference yet (they were all on '9' prior to my adjustment). I'll try '1' all the way around next, just to see if there is a difference in feel, but in the meantime, is it a problem that the rear dials did not 'click'?
You'll need to sand down the calluses on your fingers and do your best "Light Fingers Louie" safecracker impression to feel the smooth detents on the PSS-9's. If your **** spins around helplessly, you've got problems with the shock.
You should be able to tell a difference from 9 to 1 on the street. I find 9 to be bouncy, and 1 to be jaw rattling. I hope your ***** aren't spinning like Mark mentioned.
There is a definite difference in mine as well. The fronts have a definite detent. The back, not so much so you need to pay attention. So sounds like they are fine otherwise.
Hi folks
I'm kinda new to the 993 and PSS9s, but the PO has previously installed PSS9s. They're currently set on full firm, but I'm wondering the same thing... what levels of damping does everybody use? My local mechanic says middle on the fronts and full firm on the rears.
Also, does anybody have the owner's manual or instruction booklet for the PSS9s? The PO didn't have it, nor did he have the wrenches to change the spring seats. It's corner balanced by his shop, so I don't really think I'll need them anytime soon.
Dumb question, and I know I could do a search, but what direction do you turn them to firm/soften?
Cheers
Cheers
Originally Posted by Toddimus
Hi folks
Cheers
Cheers
There really is not an instruction booklet, even the installation paperwork is pretty useless.
Suggest you try 9 all round then mid range 5-7 then full firm 1s and see which you like best.....I have played with mine a lot (no smirking in the back of the class please) and have settled on 5/6 for daily driving, but the thing I love is knowing come sunny weather again I can swop to 1/2 in 5 mins for a sunny spirited drive through the country or for an AX event.
As to the back adjusters, make sure the wheel is tight, one of mine was loose and not really truning the setting. Tightened up it is now fine, but not as "clicky" as the fronts....enjoy
The adjustment ***** are held on by a small allen wrench type screw. To improve the detent feel somewhat, loosen the allen wrench screw, press the adjustment **** firmly inward and tighten the allen wrench head back while pressing in on the adjustment ****. Did that make any sense? It helps a tad. FYI I run full stiff rear, one click softer on the front.
