While I'm in there (RMS & clutch)
I have been living with a RMS leak for a few months but have decided to fix it and replace the clutch at the same time (60K miles on the current clutch).
I have ordered the following replacement part:
- Sachs clutch kit (pressure plate, clutch disc, release bearing,...)
- LUK flywheel (not the lightweight, please do not start me on that) and bolts
- clutch release fork and shaft
- slave cylinder and connecting hose (my clutch pedal suffers the hanging problem)
- master cylinder
- flywheel pilot bearing
- flywheel seal
- main shaft seal
Anything else you can think of while I'm in there?
- master cylinder
- flywheel seal
- main shaft seal
Originally Posted by DAVISRILEY
I would replace the vent valve at the top of the oil tank. Had a few of those gum up and cause the new rear main seal to leak. They are fairly cheap.
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
Don't know your mileage, and assuming you are doing an engine drop, how are your spark plug wires?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Mark in Baltimore
Why not do a LWF/clutch?
T/O fork needle bearings and seals
Kinematic pedal update arm
Flywheel bolts
Technical Guru
Are you dropping the engine to do this? If so, I'd definitely do the spark plugs, wires, power steering belt, SAI check valve, and fuel filter. And clean up the engine bay.
Originally Posted by 99three
Arnaud-
Who is doing your work and why don't you try going with the LWF?
See you in the spring.![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Originally Posted by AM993
Henry @ REFINED MOTORSPORT. Concerning the LWF, I have met/spoken to enough people who have done the modification and discouraged me. Personal choice I guess.
Originally Posted by Chuck A.
Can you give the reasons why you were discouraged? My car is in the shop right now getting the RS LWF and clutch.
