Old Yeller - Convertible Top Cleaning and Protecting DIY -PICS
#31
Nice work Mike.
I like Meguirs also for bringing a scratched or faded rear window back to life but for day to day cleaning, I ran across (can't recall where) a GREAT spray cleaner called Plexus. Not sure if I bought it here: http://www.amazon.com/Plexus-Plastic...8&s=automotive but you can see the can and description.
This stuff is amazing. Seems to lift dust/dirt away from the plastic. I have a fairly new top and I have yet to get a scratch after months of use. I use a microfiber cloth with it. I like it a lot.
They claim it came from aircraft industry... so maybe Jeff has heard of it
#32
Thanks Mark. Like I said I always like to try new products. I will order some up. I always do large orders about twice a year. Thanks again.
mike
mike
#33
Originally Posted by MarkD
Nice work Mike.
It is known as "THE" plastic, acrylic, etc. window cleaner.
#34
Nice work Mike.
Mike, I measured the rear window and it is the same dimensions as the window you posted.
I want to post a picture of my old *** (pun intentional):
You know I just yanking your chain.....
#35
Originally Posted by 993BillW
Jeff, you had a nice ***, too bad you let it get away
http://www.pbase.com/jlsphoto/baron
#37
I'm using the 303 as a protectant on all vinyl, rubber, leather, etc., so it is put on full strength and wiped around/off.
The RaggTopp Cleaner is also put on full strength on to a wet conv top and scrubbed. The RaggTopp Protectant is then sprayed on the top in multiple coats and in multiple directions.
#39
Originally Posted by 95FL993CAB
How would you do the same top cleaning if the top is still on the car?
Ron
Ron
Mike
#40
Originally Posted by InTheAir
But I'm close to replacing it with another air-cooled vehicle....
You know, I wouldn't mind letting you borrow my Cab. for a month or so so you can keep your detailing skills sharp!
#41
Boost Junkie
Yup, we use Plexus on our windscreens on the planes and I also used it to clean my plastic convertible window.
#42
I used Aerospace 303 on my vinyl, leather, plastic, rubber, etc. ....
#44
R.I.P
Great stuff here. Went out to look for the Meguirs stuff and ended up with meguirs plastic X. Did the job on the rear window. Can't believe I've been driving for the past many years without being able to see out the rear window. Great advice.
