Wheel question?
Originally Posted by LivinginParis
Is the 9,5" and 11" no problem?
Merci!
Merci!
Look here 993 info is half way down the page
You will have a problem at both ends, but especially so at the front
Also agree that the front will be an issue: the wheel is 38mm (1.5") wider than stock, so all else being equal, it will protrude 17mm further towards the fender lip than a 18x8 ET52 wheel. Easy to verify if you now have 18x8 ET52 installed.
The rear will be tight - Bills charts will guide you
. All I can confirm is that 11" ET45 w. 295/30 nicely fit the rear of a WB: 11" ET65 for a NB may be further comprimised @ RS height.
BTY, the max recommended rim width for a 225/40R18 is 9" - you indicated a 225/30R18 .... which I have not seen - but would be less tolerant of rim width deviations.
. All I can confirm is that 11" ET45 w. 295/30 nicely fit the rear of a WB: 11" ET65 for a NB may be further comprimised @ RS height.BTY, the max recommended rim width for a 225/40R18 is 9" - you indicated a 225/30R18 .... which I have not seen - but would be less tolerant of rim width deviations.
