WTB: Autometrics Tow Hook with Integrated Jack Point
02-06-2007, 11:55 AM
I am lookinig for an Autometrics Tow Hook with Integrated Jack Point.
02-06-2007, 12:21 PM
02-06-2007, 12:23 PM
Thanks, but Autometrics is out of stock.
02-06-2007, 01:22 PM
AddictRennlist Member
David, no leads for you, but if you have a 95, this tow hook will not fit. The O2 sensor is in the way.
02-06-2007, 02:29 PM
AddictLifetime Rennlist Member
Quote:
Unless you have a modified exhaust that deletes the cats.
02-06-2007, 10:51 PM
I just went to buy one of these also from Autometrics and they told me, not only are they out of stock, but wont be making them any longer. Dangit!
02-06-2007, 11:44 PM
Quote:
Wow, bummer! Well, just do what I did and drill a hole in your license plate and stick the screw-in tow hook into the bumper.
02-07-2007, 12:49 AM
Quote:
I just remove my plate when I get to the track
02-07-2007, 12:54 AM
Pat,
I'm inherently lazy and try to reduce the amount of work I have to do at the track, even if it means having to remove two plastic bolts and install a metal tow hook.
2007 ,
autometrics ,
baltimore ,
diy ,
hook ,
jack ,
license ,
location ,
matrix ,
miata ,
plate ,
tow
