993 Forum 1995-1998
how do you set rear toe/camber/caster?
Old 01-30-2007 | 02:22 AM
S4-on-your-back-door's Avatar
Default how do you set rear toe/camber/caster?
pass side rear tilts in slitely and the 275 ive put on does not rub but the drivers side is strate and goes. how can i adjust the drivers rear tire?
Old 01-30-2007 | 11:08 AM
Garth S's Avatar
Garth S
Originally Posted by InTheAir
You're not suggesting just adjusting it yourself without getting a complete alignment, are you??
That being said, camber in the rear is adjusted by loosening the two bolts at the bottom of the shock--the bottom bolt is in a circular hole and the top is in a slotted hole so that the wheel assembly can pivot about the lower bolt, thus increasing/decreasing camber.
Jeff, mon ami - that would be front camber.
'S4' .... get thee to an alignment rack - camber is the upper rear link & eccentric, which is no joy to play with at home.
Rear caster is quite difficult
Old 01-30-2007 | 12:40 PM
InTheAir's Avatar
InTheAir
Why did I think he was talking "fronts" when he mentioned rear twice?
Unfortunately, your mind is the ~second~ thing to go.
Old 01-30-2007 | 02:52 PM
so is it that hard to do? it has to adjust just slightly, two good waxs with a rubber hammer should do the trick
Old 01-30-2007 | 03:00 PM
jimbo3's Avatar
jimbo3
Boy, if this gets out, the entire alignment industry is going to fold.
InTheAir's Avatar
InTheAir
It's not extremely difficult to do, but you need proper equipment to "set" it to the proper camber (angle).
That being said, I'm lost as to why you would adjust an alignment setting just by eye-balling it, unless you are doing it to make due as you drive it to the alignment shop.
Old 01-31-2007 | 11:12 AM
dont think it a science just need to adjust camber by an 1/8 inch easy done with an level. what are these special tool? its not rocket science, and i dont think they put the car on the rack at the race track, they adjust by Incramental markings.P.S can anyone post some pics of this adjustment point?
Old 01-31-2007 | 11:28 AM
Mark in Baltimore's Avatar
Mark in Baltimore
At the track, everyone waits for high noon to use the rims and sun as suspension calibrators. It's the same principle as using your watch as a compass.
Old 01-31-2007 | 11:50 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Or just leave the eccentrics loose and drive a session -- after your best lap, pull in and tighten everything down
Old 01-31-2007 | 11:54 AM
Greg Fishman's Avatar
Greg Fishman
The problem is as you adjust camber you adjust toe settings also and this will have a major effect in your car's performance.
If you can feel the difference an 1/8 of an inch in camber makes then you are good enough to have a full crew on staff, so you shouldn't be too concerned with how to make this adjustment.
And no they don't adjust by incremental markings, they use string gauges, scales and camber gauges (at a minimum) to make alignment changes at the track. Most also have a alignment pad that is alumiumum and able to be leveled.
Changing settings is not tough, but changing them right takes a bit more skill...
Old 01-31-2007 | 12:00 PM
Mark in Baltimore
I also like to use the curbing to adjust my suspension. If I overdo it, I just spin and back into the curbing. Sometimes it takes a few sessions to get it right, but it's much cheaper than going to that nasty, old shop, and ensures my rightful spot on the HWFM Racing team.
Old 01-31-2007 | 12:11 PM
Greg Fishman
Mark and Chris,
You guys are smart. I should just use my shop manual to start fires.
Old 01-31-2007 | 02:45 PM
1/8inch is needed to stop tire from rubbing on wheel well. out of all these posts ,still havent receive any useful information or pic , has anyone done this them self and can provide pics? only interested with comments on how to do this. all other neg post or it cant be done post, plse keep them to yourselves THKS
Old 01-31-2007 | 02:57 PM
Greg Fishman
I have done this and it is not hard. Look at the suspension links and look at the upper mount for the camber adjustment.
Old 01-31-2007 | 03:00 PM
InTheAir's Avatar
InTheAir
Wow.
Here are the instructions:
1) Thicken skin
2) Click on PDF below....
http://home.comcast.net/~jsnyder99/P...993_Manual.pdf
Let me know when you have it and I will remove it from my server.
