Part Numbers: Two small rubber pieces?
Does anyone know the part number for the plugs that must have once sat in the small, circular drain holes of the front trunk of my '95 993? I could probably fit some cork bits or silicone in the hole, but it would be nice to have the real thing.
Also, I need to replace a little rubber cup that covers the rod used to tell when the driver's door is open. I thought that this wouldn't be a problem, since I can make out 901 615 618 20, but Pelican recognize it.
Thanks for your help.
-John
-John
According to PET it there are two numbered 964 504 209 00 and two numbered 964 504 213 00. The last two are for the spare wheel well.
No doubt they'll cost a small fortune from the OPC!
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
901 615 616 20 price $1.57
Technical Guru
