Major Audio Upgrade - LONG w/ Lots of Pics
My 993 audio upgrade project (Tim had the interior practically down to the metal) is complete. Tim spent a lot of time ensuring the wiring was perfect (he doesn't do anything halfway and I can't say enough about the first rate quality of literally everything he does...incredible). The first thing we did was 86 the PO installed lo-jack and secondary alarm (looked like Helen Keller installed both)....the low jack was loose in the trunk with a battery literally duct taped to it while the alarm wiring looked about ready to burn the car to the ground.
I was initially going to do the Rod Birch "System" (I've heard nothing but praise for it) but there were two issues. I had to 8" subs in my previous 996's and the bass fell short IMO. And more importantly, I wasn't willing to give up both back seats. So....Tim built a custom fiberglass enclosure behind the driver's seat (no one was ever going to sit there) to accomodate a 10" JL Audio 10W3v3-4 300W Subwoofer (OMG the BASS). BTW we kept the template in case anyone wants a similiar setup.
The system is comprised of the single JL sub (no one is ever going to say "you need more bass"). Alpine ICE Power Amps 1 PDX4.150 (600 watt 4 channel 150 watts RMS each) driving MB Quart QSD216 6.5" Components (front) and MBQ QSD215 5.25" Components on the rear deck. A 2nd Amp PDX2.150 is bridged (300 watts RMS) to drive the sub. A note on ICE Power...Alpine licensed this ultra high efficiency technology from Bang & Olufsen and let me simply say they are incredible, VERY LIGHT, and totally exceed expectations. Learn more here http://www.icepower.bang-olufsen.com/sw1022.asp & here http://www.alpine-usa.com/US-en/prod...odel=PDX-4.150 We also installed an Alpine head unit (CDA-9857) with CD, XM Radio and full speed IPOD control. Double redundant 80AMP "Stinger" fuses were used to fully isolate the audio and core automotive systems. An independent failure will not affect the other. 4 & 8 gauge wiring and "Stinger" RCA's as well. With the Alpine amps ultra high efficiency (the deck is set to passive output) there is no concern about draw and no capacitor is necessary.
We're still fine tuning the crossovers and AMP's but overall it's an incredible upgrade and since this is my daily driver with frequent jaunts to LA and back, I'm very very happy (the car is very loud to begin with). Naturally Tim had to throw the car on the rack for a fresh alignment and corner balance to dial it back to...perfect?
Here are some pics.....
- Jordan
- Jordan
Looks good Jordan! Thanks for posting your install info and the links. One of my winter projects is a new audio system in my car. I picked up an Alpine DVA9860 from another Rennlist member as my head unit and just need to get going on the rest of the setup.
Rear Speakers
Originally Posted by ce_hensley
Lets see the rear speakers...
As for the sub enclosure....this is a piece that according to Tim can only be duplicated and fit to a car that is actually in the shop unless the recipient is potentially prepared for additional work and/or shaping which isn't ideal to Mind. Mind is not an authorized audio shop of course and typically does these one off's on a project by project basis and would likely do another complete system only with customer supplied audio components.
- Jordan
Nice setup. Looking for a new headunit here. Prefer the look of the old Nak decks but need to research more on what a good headunit would be. The old Eclipse isn't picking up radio stations too well these days. Probably gonna lose the amps as well as they're too freaking heavy.
