RSCS Clone Transformation In Progress
#32
Awesome project! GL. Did you ever find the wheels you were looking for?
#34
Originally Posted by Mark in Baltimore
Rob,
I believe Greg Fishman had an RSCS tail on his C2S race car. It looked just fine to me.
#35
AC993, an interesting project!
I have a genuine un-modified 993CS currently under a cover in my garage, let me know if you need any clarification of some of the finer points of the conversion (pics etc)......looking forward to seeing things progress
#36
Clubsport1,
You could make this real easy on me by just shipping that CS over here to me.... Thanks for the offer, and I may just take you up on some pictures in the near future.
#37
Splitters arrived today from MA Shaw...very nice pieces. Along with the new rubber... Carpet going in on Thursday...
#38
You are going to want to reinforce that middle section. I used some steel plate between the middle and outer sections on the bottom where it can not be seen. Then I drilled and used numerous large pop rivets to hold it together. Otherwise, the way it is designed it will break real soon with any track run off or street scraping....
#40
Looking at the splitter photo and Viper Bob's suggestion to reinforce it.
Mine looks similiar and weak; has a couple of pop rivets each side; maybe I will reinforce it as suggested.
Thanks - I can watch Rob's progress and use it to compare to my own (finished) project.
#41
The MA SHaw piece has 2 10mm bolts/nuts (pre-threaded) PER side to attach the end pieces, not rivets....I will still heed VB's advice and go further with the reinforcement. 993inNC just ordered a one-piece GT-2 splitter from a company out of NJ (it doesnt have 3 connecting pieces, but I dont think it would be any stronger than this one (reinforced). In fact, I would think the reinforcement would make this the stronger piece. Chris does report excellent fitment, however.
#42
I happen to have some plate aluminum, and may make a piece to cross from left to right. It'll act as a strengthener as well as a scrape plate since those bumper protection bars would be useless with the splitter.......go idea guys.
I was thinking the one piece unit would be stronger since it will take a hit as one entire piece as apposed to the center section taking the brunt of it.
#43
Rob,
congrats on a great project. I have a 993 RS project I've been working on for WAY too long. In the picture with the factory side skirts, I see 2 large black plastic pieces. Are those RS pieces that fit into the wheel well & the side skirt? If you don't mind, can you post the part numbers? I have a full factory RS body kit that has NOT been installed yet. However, I am pretty sure I do NOT have those black pieces you have pictured.
Cheers,
Kyle
Cheers,
Kyle
#44
Kyle, yes they are factory pieces that fit in to the wheel well to "fill the gap" that is created by the skirt being mounted. The part numbers are:
993.504.481.00 (the left is identical to the right and carris the same part number)
Rob
Rob
