Project: Custom Spoiler Control Module
Uhhhhh... it's for the AUTOBAHN.
Uhhhhhh.... it's for the AUTOSTRADA.
ya ya that's the ticket (or, aplogies to The Grinch "He thought up a LIE and he thought it up QUICK")
Dindo
Im wondering if you are thinking a DIY kit or just complete assembly? I, like you, love learning and to me its enough of a challenge to build the module based on your original. I understand that others dont want to mess with it and would prefer a complete module. Either way, you could recover your time/costs if you offer the boards or a BOM kit for those that want to build themselves and save a little $$. Im still using the OBDI DIY board and LOVE IT! Already saved me money by disabling a false airbag warning when my steering wheel was out.
Here is an attempt to answer a bunch of previous messages. In the next message I post, I'll address the "challenges" of making this a kit or product.
It's doable but I'm going to need help with a couple things.
I also need to make sure everyone understands that this is my amateur-level design work. It's been very reliable on my car (no failures at all), but I have no MTBF (mean time before failure) information on the parts I used, and I can't guarantee it will work for 10 years (or 2 years). I think it is pretty well-designed and will last a good long time, but who knows? So we'd need a common understanding of warranty issues/support, etc. But I'm willing to give it a shot if others want to try it. It's also possible that a few of you could beta-test it and any needed refinements could be put in before a bunch of people get it.
Turn it into a real product
Make it available as a kit with all the parts needed.
Make the board and a parts list available
License it to someone who does the first thing
Run away
What are your thoughts?
PS I wish I'd done it first. Good stuff.
) but could be wrong. Free time will be my constraint here.
the tail has an aerodynamic function - to reduce lift at the **** end of the car at high speed.
Using your program if I mat the gas at say 40 MPH, with a 10s delay after 65 the car is going
to be going like 120MPH or more by the time the tail starts to rise and by the time the tail is
fully extended the car could be over 140 MPH. I don't think you want the tail down at that speed.
So. The improvement is:
Put up tail if tail is down and:
(switch is activated UP
OR car goes 65 MPH or more for 10s continuously
OR car goes 75 MPH) <--- This is the new part.
THis way, on my high speed blast example the tail will start to go up at 75 and by the time
I'm at 100 or so it's fully extended.
What do you think?
On the spoiler module: I'm open to building a few or setting up kits, as long as everyone understands this is not a stress-tested product (yet, but it could be if we get some testers going), and also if we can overcome the couple issues I'll describe in my next post.
Colin
-Jim
As to a version that does less, the parts count can't be decreased much. No matter how simple the behavior gets, you still need the circuits in place.
1) I can't find a source for the male connector. I had to fab one, which is not viable for a kit or assembly. It's a 12-pin, two-row connector with 7mm pin spacing and 14mm row spacing. See pic below, and here is a link with more pictures. Can anyone help with this?
2) Case size with this board is slightly large. It WILL fit in the stock location but I should probably compact it. That means finding a new case too. Or maybe it's OK as-is.
Sorry about the poor focus on the picture. The rear one with the LEDs is the project in the aluminum box, the front one is the stock module.
Without my kids, life would be pretty boring in comparison!
