Found a guy on ebay. Big foot tiles. Basically a race deck replica that worked out to be under $1.60 a square ft shipped. Thought you guys would love the results
What do you do for the trim pieces in the corners or around the pole??
Looks great.
you can purchase edges which are like mini ramps that snap in to complete the look. I will attack a few tiles with a circular or jigsaw for around the pole. I'll hopefully complete the job this weekend.
Looks really good and an excellent price. As far as a jack or jack stands, a jack stand will definitely punch a hole in them. I use a metal sheet under my jackstands. I haven't had a problem with using a jack on the plastic pieces.
The Racedeck pieces have a raised checkered pattern underneath with cutouts to allow water to drain. The top flat portion looks to only be about an 1/8" thick. Unfortunately my jackstands have pointed legs which can punch through into the open area underneath.
This shows what I tried to describe. LT1, do yours look similar underneath?
Wow... I can see how a jack stand can punch through that? So do you find it effective for water draining? What LT1 has for $1.60 is pretty darn good.... but I don't want to do it if it will not hold up.
Mine look virtually idential to your picture. I see you cut that tile. What kind of saw/blade combo worked out best for you?
tony...
Quality seems good although I havent done a side by side comparo to Race deck. I didnt ask about any warranty. If you bust a tile, you can always snap a new one in.
