Mounting Tires on a DIY Wheel Repair
Hey guys,
I picked up some Cup IIs with some road rash. I've been searching through the 993 forum and would like to try to repair these wheels. But I am wondering if those that used putty/bondo on the lip had problems with the repair breaking away when a new tire is mounted on the wheel, i.e., will the rotating arm used to put the tire on the wheel knock off the repair? Anyone with problems/success mounting tires on a repaired wheel?
Originally Posted by tomcat
Hey guys,
I have had success using a thick "crazy glue" (cyno-whateveritscalled) to fill minor rash/srcatches. It cures pretty dang hard and is sandable. No trouble having tires mounted.
No experience with body filler.
Thanks Mark. Your solution sounds good to me. The lip doesn't really need to be built up - just filled in.
I've actually repaired dented fork tubes with metal filled epoxy, ie jb weld. It will sand and finish well... even looks pretty close to alum if not painted.
Michael
Cosmetic use of bondo on curb rash is standard procedure in making the surface look smooth again. I refinished a set of cup2s myself a few years ago for light winter duty and they have perfomed flawlessly and still look new. Just make sure you give the paint plenty of time to cure, take the wheels to a place that has a proper mounting machine that doesn't actually touch the rim itself - and tell them you refinished the rim yourself - and you'll be fine.
Originally Posted by c993k
Take them to a shop that does wheel repairs.
It's not that much money and they come out like new, balanced and shiny and most of all safe.
The road rash is just surface problems (i.e., the lip doesn't have chucks missing from it). I figure, if it doesn't come out right, I can always send them to the shop.
Bus, the JB Weld sounds good too.
