993 Forum 1995-1998
Suspension and clutch advise
Old 11-23-2006, 12:18 AM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by Peter R
The major problem with these issues is that there seems to be no guaranteed fix except for a complete ECU swap or reprogramming.
There are currently no aftermarket performance chips available for the MY95 993 that fix the LWF stall problem.
Old 11-23-2006, 01:21 AM
RustyRotors
RustyRotors's Avatar
Default Thanks for the great clutch pics - and it is a 1996 C2
I removed the ECU over the weekend to explore the possibilities of chiptuning. I could not beleive how protected the ECU was covered under the seat. Why is the cover blind rivetted on with shear bolts from under neath the pan. You have to drill it to get it out.
I do also intend to replace the slave cylinder. I already have a clutch kit and a complete set of release mechanism bearings and cups and clips to go along with the slave cylinder and release bearing.
Based on that info, perhaps I do not need to go in there at all!!
I will keep you posted as things develop.
Thanks again to all!!
This place rocks!!
- Ron
Quick Reply: Suspension and clutch advise
