2006-2007 Winter Projects?
Originally Posted by Flying Finn
Winter projects? Below is what I'm planning to do.
Sorry, couldn't resist, I've "been there, done that" in Finland. While it's cruel to not to be able to drive, I like wrenching winter projects too. And that first drive when the spring comes, oh yea!
Some long lists here...
Here is mine (short version):
- Drop Engine/trans - Done
- R/R Flywheel/Clutch - WIP
- Replace everthing that needs to be replaced while engine is out (some stuff done, i.e. engine sound proofing replaced.) - WIP
- Replace 1 outer CV boot
- Upgrade supsension to M030 with Billsteins - Kit on the way
- 18" Wheel/tire project (incl. repaining new wheels black)
- Repaint calipers
- Keep wife happy while draining funds - WIP
That's All Folks!
- Repaint calipers
That's All Folks!
Originally Posted by InTheAir
Mark -
While the engine is out, you might want to replace the SAI check valve.
Second, my 993 is a 95, do I need to? Is there a downside if it doesn't function at all?
It turned out that the small switches behind the passenger side panel were not properly tripping during actuation. Relatively painless to adjust.
Okay, I'll play...
993
Short shift install
Paint wheels
Steering rack brace (need to verify if there or not) It's there - DONE!
LPMM
Replace hood crest gasket
Badge delete (maybe)
Paint rear grill/bumperettes (maybe)
Trunk/decklid struts - Done
3-spoke wheel - Done (sweet!)
Repair sunroof - Done (dirty plug)
Drive, Drive, Drive!
911
Final debug carbs
Repair main seal(leak)
Trailing arm bushings
Paint race wheels
Modify swaybar links
I suspect most of these will become New Year's resolutions rather than winter projects!
993
Short shift install
Paint wheels
LPMM
911
Final debug carbs
Paint race wheels
Drive with aplomb through snow drifts
Clean off the salty slush whenever it gets above freezing
Perhaps replace the stereo head unit with an iPod friendly one
Install RS Front splitters if I can find a good deal
Fix things as needed to keep car operational.
Come spring/summer:
Replace shocks with Bilsteins all around
Maybe replace the clutch
Catch up any maintenance that it was too cold to do all winter.
Come spring/summer:
* fit Momo Mod07 steering wheel (DONE)
* remove a/c, I will leave lines in though.
* fit single pulley part from Patrick Motorsports
* steering stop mod for 18" wheels, and flattened oil line.
* fit 18" wheels
* remove more sound deadening on back shelf
* purchase/install new gps data logger
* fix screws on my RS door panels
* put in new clips for valence and shark fin
* rennspeed battery kit with Odyssey battery.
I think thats it.
* fit 18" wheels
I think thats it.
