993 Forum 1995-1998
Help Putting a C2S Split Spoiler Together
Old 11-09-2006, 01:28 PM
Chuck W.
Chuck W.'s Avatar
Default Help Putting a C2S Split Spoiler Together
I bought a C2S split rear spoiler. I just got it back from the body shop that painted it for me. My question is how do you put the four pieces together? I was thinking some type of adhesive but noted that there were studs on the upper pieces that protrude through the lower frame. Perhaps it was designed for speed nuts or something like that.
If anyone has successfully put one together let me know how you did it. With my talents, I am sure if I don’t follow a knowledgeable Rennlister’s instructions I will have a panel will come loose and fly from the car while driving. TIA
Old 11-09-2006, 01:40 PM
Father of 3
Father of 3's Avatar
Very nice Chuck. This is one thing I'd like to do at some point. Are you going to the Callas event?
Old 11-09-2006, 01:41 PM
Chuck W.
Chuck W.'s Avatar
When I am done I'll post some photos. Not sure about Callas'.
Old 11-09-2006, 03:06 PM
24FPS
24FPS's Avatar
i know coleman has the split grill on his beautiful c2 which he added... do a search... weird i don't remember reading any threads on the actual assembly here (maybe pelican?) sure gert would know how it works...
chuck did you already remove your old grill insert???
i remember reading that it is a pita ( curious b/c i'm thinkin' of the same mod ) ... does it in fact envolve prying & breaking out the old b/c f the cement/glue holding it in place???
tia... btw: please do post pics, bet it will look beautiful in white!
Old 11-09-2006, 03:08 PM
Caveman
Caveman's Avatar
If you look on Ebay (I think .co.uk rather than .com) there is someone advertising them from China and they have pictures of the pieces together. Looks like pegs in holes and presumably locking puch-on clip thinggies? Sorry about the non-technical term.
Cheers,
David
Old 11-09-2006, 04:19 PM
Bradford
Bradford's Avatar
There are retaining clips that press onto the studs from the grill that hold it on. You will notice these when you remove your standard grill. I used a black marine sealant around the perimeter where it makes contact with the lid and the center piece. You must seal it in place. Let me know if you need anything further.
Old 11-09-2006, 04:24 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
I am looking for this very grill for my car if anyone knows of one for sale..
If it mounts like the std. plastic grill, there are speed nut looking stamped metal star washer thingies that simply press onto the plastic pins. Hope that helps..
Old 11-09-2006, 06:07 PM
993C4Smontreal
993C4Smontreal's Avatar
chris,
this guy that sells them on ebay. do a search by seller for "msroadrace"
appearantly, a lot of rennlisters buy from him.
Old 11-09-2006, 06:40 PM
David in LA
David in LA's Avatar
That's a nice mod...how much did the shop charge to spray the pieces? The split grill, side skirts and turbo s front spoiler are about the only remaining cosmetic mods left on my list.
Old 11-09-2006, 08:20 PM
Kigiin
Kigiin's Avatar
I paid about $100 to have my split grill sprayed. It already came prepped from Gerts.
Rob
Old 11-09-2006, 09:25 PM
24FPS
24FPS's Avatar
Rob
ooooooooo... ahhhhggggg (looks fresh!) ... i like the assembled idea alot.
Old 11-10-2006, 06:06 AM
geolab
geolab's Avatar
Pages 955 to 962 in the workshop manual
http://www.cannell.co.uk/Manuals.htm
Old 11-10-2006, 11:57 AM
Chuck W.
Chuck W.'s Avatar
Perfect, thanks.
Old 11-10-2006, 12:59 PM
Cactus
Noodle Jr.
Cactus's Avatar
Does anyone have the split grills on a NB?
Old 11-10-2006, 02:23 PM
geolab
geolab's Avatar
Originally Posted by Chuck W.
Perfect, thanks.
Chuck, I would strongly advise you to get the glue from the dealer,
and apply it as per the manual.
Some have witnessed warping, and it may be caused by using alternative glue.
Quick Reply: Help Putting a C2S Split Spoiler Together
