Have COSTCO MotoFloor garage floor tiles?
I have Motofloor tiles in my garage. There are a few more pictures in this thread.
I came from a house where I did a U-Coat-it epoxy floor, and decided to do tiles in my new garage.
- Hard to keep clean, especially the white ones
- Have to be careful using jack stands/jacks/heavy equipment
- Loud to walk on (they are hollow underneath, with ribs for support
+ Nicer to kneel on than concrete
+ Look great
+ EASY to put in, take out, and rearrange. The epoxy was a real pain, even on new concrete
All in all, I like them, but they seem oriented more toward looks than easy cleanup and heavy projects. I'll just have to be careful.
I can't remember how many pieces were in the completer kit, but I used ONE kit in my 400 sqft garage, which has one double door, one side door, and one hallway door.
+ Look great
Sounds like something I would like to do.
What's the expected pricing for the 2 car garage kit?
I have a 3 car garage, but no need to put tiles down for my wifes Z4 (just kidding, sort of).
Go with Swiss-Trax. I found them thanks to someone on this board who posted information. Diamond trex are really impressive. Sturdy, sharp looking, quite, easy to cut, and super easy to install.
They have a sweet clearance deal going on too.
This past summer the costco kit was $30 off ($89 for 45 sq ft). Maybe Ill wait to see if they go on sale again. Dont mean to highjack thread, but has anyone tried the PVC roll-out flooring? It seems like it might be lower cost than tiles and easier to install. However, Im concerned that the PVC might not hold-up to jack stands etc.
I have the pvc roll out stuff in my regular 2-car garage. I bought 2 10x24 (?) pieces and made it "wall-to-wall". It did a good job covering up an aging/peeling epoxy floor, but I would not recommend for a working garage. Jack stands would trash it and the ribbed style hurts to kneel on. It also gets water under it if it rains and the garage door is open - very hard to dry and it can mildew under there. I have black & white Armstrong glue down tiles in my Porsche garage - I put solid black where the car parks so no problems with the tires leaving marks. You still need to be careful with jack stands, but it looks gooooood!
Originally Posted by martyp
If so, how may edge pieces in the "completer kit"?
And how do you like it overall?
Thanks!
M
Thanks!
M
I have a 1400 sq ft shop and ended up needing 2 "completer kits" because I had more edges to deal with. Only tiled the car portion of the shop. I just went out and counted... there are 20 per kit. The completer kit also comes with a stack of extra tiles... more than you would think. I suppose these are to help fill where you need to cut tiles.
I used a chop saw to cut them.
Very easy to install.
Very easy to keep clean.
I did the same thing cowtown did and "surrounded" my lift.
Only wish I'd have gone with the black and white. The grey doesn't look as good IMO.
I have a love/hate relationship with my DIY epoxy floor. It has pulled up in areas and the new tires of my wifes SUV stained the floor. Also, any oil that is left on the floor has stained it. I still think it looks better than original, but I cant look at it too close or I get disappointed. Im thinking that the black glued tiles just for the car area might be good. I have epoxy in the non-work areas and its holding up well. The black tiles under the car will clean up the floor, but Im scared of the tiles lifting if they are glued to the epoxy or constantly getting cut from use.
Does anyone know if a flooring exists that can take the abuse that a 993 DIYer can dish out on it?
IMO, a floating tile floor like the MotoFloor or Swiss-Trax is best for reasons already stated above. It is very durable, oil and chemical resistant... I have tried to hurt it. So far so good.
I went with the MotoFloor for $$ reasons. I couldn't justify the extra cost of a couple of other brands.
However, with SwissTrax and others you get MANY color and surface pattern choices.
+ Look great
+ Look great
I have the pvc roll out stuff in my regular 2-car garage. I bought 2 10x24 (?) pieces and made it "wall-to-wall". It did a good job covering up an aging/peeling epoxy floor, but I would not recommend for a working garage. Jack stands would trash it and the ribbed style hurts to kneel on. ...[snip]
http://www.pelicanbbs.com/showthread...hreadid=312166
Sounds to me like the best solution for a working garage is Racedeck, Swiss-Trax, Costco (which is Racedeck), or Kiwi. All are interlocking tiles. Jacking on glued Armstrong tiles is apparently dangerous per some posts on pelicanbbs.
FWIW, I put down the PVC roll coin pattern flooring earlier this year. 2 10X24 to cover a 2 car garage was what I needed.
+ Quick and easy to install
+ Easy to keep clean
+ Oil, fluids wipe right up
+ Covers a cracked concrete floor without the hassle of refinishing
+ Less dust, easier to sweep.
- Tire spots where car parks
- Seam where two rolls butt up against can expand and contract leaving a gap
- Can't use regular jackstands. I needed to use wood underneath the jackstands to have a smooth platform. Will get some AC jackstands and that should solve my problem of jackstands cutting through the vinyl.
So far though, the flooring has held up well to regular maintenance of the Porsche. Just finished a 60K and was able to clean up the floor easily.
Also did some suspension work on another car (control arms and bushings) and again, it was no big deal. Much better than working on bare concrete.
-travis
-travis
