Motive power bleeder sources
Seared
Originally Posted by RallyJon
Do NOT, however, get their bleeder bottles. The hard plastic nipples between the hose and cap are very brittle and snap easily with any side load.
I had the same experience so I went to Home Depot and picked out a few brass connectors to replace the plastic bits with. Works great.
For that matter, any clear bottle would work for this application!
Andreas
Burgled
I went to the dollar store and got a couple clear graduated plastic bottles, drilled a hole slightly smaller then the aquarium hose I had and just stuck the hose inside all the way to the bottom. Cheap and works great plus you can see how much fluid ounces you drain.
