Headlight adjustment - How to?
I have factory Xenons or Litronics or whatever they are called. For some reason the PO had one waaaaaaay out of alignment. No idea why or how but how can I adjust the beam without the special adjustment tool. Looks like some sort of star style allen key is needed to do this.
It is a normal allen wrench though I can't remember the size offhand. You could pull out one of the headlamps to check out the size. There are two adjustments. One for horizontal and one for vertical adjustments.
I did not have a long allen key, so I just pulled the whole headlight out, turned the adjustment screw a bit, and put it back in. About 47 times. On each side. It was a pain, but it worked!
