Varioram help req.
Does anyone know how to setup a stand alone fuel system (electromotive tec3r) to run a Varioram intake system. I just picked one up and have no idea where to start! I used the tec3 with the 95 standard black ABS intake that has a single switch to open the bottum tube and had no problem with that but I have no idea about the Varioram. Also if I could see what the plumbing looks like and vacuum tube routing was that might be a start. I'm sure someone out there knows I just need that persons help...
NineM.... Just one more thing if you don't mind. Can you tell me what I need and don't need as far as connections on the back right side of the varioram? Because my car is a 911 conversion the only thing I used on my old 964 intake was vacuum for the brake booster, this intake has many other connections I'm not sure about.
Mind coming to the party again?
Thanks!
Thanks!
