Spark Plugs, 2 electrode or 3? Why?
Different car. Vince has my old '97 Cab and I now have a '97 Coupe since I started this thread. I have put on almost 12k mi. on the coupe in the 2 yrs I've had it though.
To reply to the main question, after my curiosity questions answered along the years
Why two spark plugs:
compressed air fuel forms two pseudo bulbs-clouds if not ignited at piston drop down after top compression. So two spark plugs is two ignitions at two places thus more efficient combustion, cleaner etc.
As per bosch engineer, two spark plugs (also) permits the use of cold spark-plugs instead of one hot spark-plug thus less cylinder head heat.
Turbo with one spark plug? yes, HOT spark-plug but cooler air from intercooler, lowers head temperatures.
Could we use the turbo hot spark plug in the NA engine, yes, but it is advised to use the cold spark-plugs
Why three electrodes:
because ceramic is bad heat conductor, the three electrodes makes the spark plug tip have a larger contact area and transfer more heat away from the spark plug tip.
So bosch FR5 DTC has a different heat range than the Beru 14FR6LDU
If someone knows somebody different at bosch to confirm, would be great
