What tips are these?
These large oval tips are marked 'EP 5110', and were attached to Bischoffs on my parts car (C4S) ..... but they have the centered mounting cone for NB cars
. I have the identical mufflers on the blue C4S, but the tip offset is wrong.
Before I begin either a muffler swap, or a 'cut & paste' in an attempt to mount these tips, is there a corresponding part for the WB? ... or any info on these well made tips?
They look like the narrow body 'big ovals' think you need the ones with the pipe offset differently. Think 7110 is the number, I had exactly the same problem was sold a set with the 5110 marking and was told they would fit a 4S, no chance without some cutting and welding.
Sold them on through ebay, as the seller wouldn't take them back. Try a search as there was a post with all the part numbers of the different factory 'big ovals'
regards.
regards.
Originally Posted by pezza
Appears that EF 7110 is the version I need .... now listed at $630 new
Originally Posted by Garth S
That it does!
---- helps the decision to modify these ... unless someone has a set to trade. ( I dismantled the parts car prior to proper schooling in WB vs. NB .... so haven't figured out how they were made to fit: maybe the rear valance was cut??)
Finding a used pair is like finding gold
