Flickering Headlight
Hey guys,
I am experiencing an annoying intermittent headlight flicker on the passenger side. Seems as if something is loose because it will go off/on when it hits a bump. I have the Xenon Catz upgrade that was installed by the PO. It's been over 2 yrs and never had this problem until recently. I took the headlight and and examined for a possible loose bulb or connection, but only found that the metal spring that keeps the bulb in place partly snapped off. I was able to hook the spring back up so that the bulb is tight, however the flickering still exists intermittently. I've removed the light again to make sure that the metal spring is still in place where I left it and it is. That doesn't seem to be the issue, but I can be wrong of course.
There is also a contact that is attached to the car itself that touches the headlight assembly when sliding the light back in which appears to be a bit loose. I haven't taken the driver's side light out yet to compare (which I probably should, before asking here).
Anyone else experience this "flickering"? It's pretty annoying, esp. for the cars in front of me I would think!
Any help or suggestions would be greatly appreciated. Thanks.
Try checking the connection where the headlight plugs into the wiring harness in the headlight bucket. Mine is cracked preventing a good connection. The fix - remove front wheel and fender liner, reach up from the back side of headlight, and press on the connector (against headlight housing) to ensure it is plugged in and making a good connection. Then, only remove that headlight when absolutely necessary, as it is a pain in the butt to get it properly re-connected!
This could also be due to the poorly designed housing and clip that holds your bulb in place. Your dealer has a retro-fit for the clip attachment, but these fail too, causing your symptom. Continued replacement of the clip is one (cheap) solution, a new (and expensive) housing is the other.
I had this experience with original litronic twice a couple of years ago,
give the headlight a dry slap when it does that, and it works. yes I am serious.
My bet is you have a bad lamp connector. Same thing happen to my Catz lamps. I replaced both with the Vertex Lamps. In hind sight, I should have just repaired the connector.
Originally Posted by grmnxtc
Headlamp bracket repair kit
000 043 204 28 about $3 a pop. (Pelican shows $2.41 each)
My problem was in the connector that is missing in the photo.
Hope this helps. I do not have a part number for the connector.
We left the connector off it's bracket so that I can drive at night, but will this pose a problem? What's the significance of the bracket if it's going to be wobbly anyways?
It's probably broken like mine. The connector has a clip on the top and one on the bottom that connect it to the bracket. My bottom clip is broken, thus a wobbly, poor fitting connection.
I had the same flickering that I traced down to the connector being the problem. Like you, I took off the connector on the bracket side and plugged it directly into the headlight... problem gone. On closer inspection of the pins in the connector, I found one to be pushed back a bit... just enough, I guess, that it would make intermittent contact when the headlight was slid back into place.
Try examining the pins on both sides of the connector to make sure they have not been pushed back a bit.
Good luck!!
Good luck!!
