Anyone using the Protomotive Stage 1 Turbo System?
Protomotive has a Turbo system for 993NA that brings them up to 400BHP+ for $12K in parts.
That sounds to me as the best choice for the money.
Has anyone done this yet? I'm really interested in hearing the results.
http://www.geocities.com/protomotive/obd993.html
Chris
Chris
Todd is well regarded and there are a few here who have Protomotive systems although I don't think anyone here has doenthe OBD Stage 1. IMHO, I think the OBD Stage 2 is the way to go.
I'll be watching this thread closely, since I am seriously considering this mod myself. I'd really be interested in some real world feedback between the stage I and stage II systems on the subject of driveability and durability.
Michael
Michael
Hmmm... keeping the stock compression seems risky at best. The only way I would go with a turbo system is if the whole P/cs were dropped to 8:1 and the valve train beefed up. Slapping a TT system on a stock NA engine is a bad idea. Besides, you can get a tt engine complete for about 20K or better yet just buy a TT. I think that there is false economy in the bolt-on systems, with the exception of the TPC supercharger.
Freddy, I am interested to learn more from you about increasing the size of my car's oil tank, so will I be able to reduce my temps (before my engine breaks that is?). Can you please elaborate on the technical side of it?
BTW what is that thing in the pictures?
There is no risk with high compression engines, they just reduce the boost levels, these cars will run at 0.4 Bar or so, they have springs in the wategates that prevent them from going beyond, unless you use a boost controller. An intercooler is a must do, otherwise, don't even try to run them on a track. The N/A heads, intake and throttle body are more efficient than the turbo engines, let alone that they are twin plug, so the results are outstanding at low boost as a result I would expect them to have great low end response, better than a 993TT.
As far as value, I don't know, I would probably buy a 993TT altogether, but the cost is not the same either. I also don't know about those power claims but knowing what they build, I am sure it will be fast.
You might want to check the 964 board, usually there is always someone who has this sort of conversion. Here is a similar one but it is a stage 2 or 3 I think.
![](http://forums.rennlist.com/upload/proto_conversion.jpg)
![](http://forums.rennlist.com/upload/proto_conversion_2.jpg)
Jean,
That thing is far from my taste... but it is fast... very fast. It was dynoed at 900hp... (I did not see it at the dynamometer) but it drives really fast - and this is something I can confirm. Regarding the oil tank larger capacity all I can say is that it is a silly thing that is used on some of these cars that I do not understand... Maybe you could teach us the benefit... all I know is that this car runs with more than 20 quarts of oil...
Freddy
Freddy
WOW, you guys have definately got my full attention. Im interested in the stage I turbo....I'll be watching this thread. Like to see how it does. 400 hp would be a dream! Looks like I the only other expense would be the turbo tail?
My $0.02
