Higher mileage 993's, How well are they doing???
#63
ps - thanks for the Birthday wishes!!
#65
107K and counting on a 96 C4. Great car. New brake master cylinder and resevoir replaced by dealer at purchase with 82K. IA aluminum valve covers for the lowers to fix oil leaks. LWF/Clutch/slave cylinder and rear lower control arms replaced at 90K. PSS10 suspension replaced the original setup at 95K to include bigger sways, new tie rods, and poly bushings for the front control arms. Drives like it is on rails now. Had one road trip issue with a bearing failure on the alternator that was fixed in half a day by Brumos and I was on my way. No other issues other than the CEL for the SAI. I replaced the SAI valve to no avail so the next task would be going after the ports. Maybe when I do a top end rebuild, if that is ever required. Oil use well within limits. Time for new tires soon - standard.
#66
#68
msw, in general, what is your driving style? I looked through a few of your old posts when I read of your car in this thread, and if I remember right you do a lot of highway miles, with minimal city driving, is that correct?
How often do you wind it out to redline? I've seen a number of posts here that indicate that the more the engine is used regularly to it's full potential, i.e., 4k & 5k+ RPMs, that they can actually run better, and I'm wondering if that holds true in your case.
I don't mean to say that an engine used exclusively in a track toy would last as long, just one that is exercised regularly and driven hard once in awhile, but consistently... Maintained well, driven conservatively at less than operating temps, etc.
Also, I noticed you've been through 3 or 4 sets of Bilstein HD's. I think I've also read that they are rebuildable, and I wondered if you meant entirely new shocks/struts each time, or just rebuilds.
#69
Purchased 5 yrs ago with 48K miles - now at around 84.....hmmm 4-8...8-4......
Outside of the standard stuff done at the 60k service:
-starter motor
-steering rack
-front tie rods
-some obscure rear trailing arms or something or other due to split rubber pieces (nice....$500 in parts for non-replaceable rubber bushing thingies...whatta deal!)
-brake master cyl
-replace air dam in rear retractable spoiler
-dampers swapped for PSS9s
-rotors all 4-corners
-pads all 4-corners
-top end (new: plug wires, valve guides, rings, every seal or gasket possible without cracking the case in half)
-rebuild distributors
-replace all plug wires due to misfire codes and putting it off at the 60K service
-clutch
-two window switches
-a few light bulbs in the guages
-two sets of front tires- three sets of rears or was it four?
-front bumper and hood respray with clear film wrap (recently messed up by some female ditz who thought she was putting her car in forward not reverse and I didn't notice the damage..."golly, F and R on the auto tranny selector look so much alike!")
-wiper blades
-resolder connectors for some leds in third brake light
-reweld door check strap
-replace faulty reverse light switch on tranny
-replace on way Y-valve for headlight washer fluid lead to nozzle (big fun - front bumper removal DIY)
-starter motor
-steering rack
-front tie rods
-brake master cyl
-pads all 4-corners
-clutch
-wiper blades
#70
-starter motor
-steering rack
-front tie rods
-brake master cyl
-pads all 4-corners
-clutch
-wiper blades
-starter motor
-steering rack
-front tie rods
-brake master cyl
-pads all 4-corners
-clutch
-wiper blades
Might not be too late to get a buy-back from the factory.
#71
#72
joining the party a bit late...
Just clocked 130k miles! Car looks and drive fantastically. Cost of ownership has been outstanding (I've had the car since late 1999), much better than the POS 97 BMW 540i I have.
#73
mongrelcat,
no track time. mostly highway miles (trek through san francisco to highway, then another 25-50 miles to offices). but it goes everywhere.
no idea if it effects anything but-
1. drive rpm well above 3 and very close to 4...figure that's why the germans put 4 at the 12 o'clock position...also if I remember, slope of torque curve is steepest just above 4 for those quick getaways...
2. take out of gear at light
3. drive as much as possible...absolutely no question runs better when driven...and driven hard
4. redline...don't know how 'often' but it definitely sees it
i always 'replaced' the HD's...no offense but i'm never sure what i'm getting with 'rebuilt'
#74
