ZMS Flywheel: a mid-weight dual-mass option?
Weathergirl
So after reading all the LWF threads, I remember seeing something in Adrian's book:
Searched the archives and found nothing. Anyone have more info? Can it be fitted to regular G50/G64 'boxes?
The 993 GT-2 is fitted with a special lightweight noise reducing DMF called the ZMS flywheel...Double mass ZMS version 8.6kg (19lb)
I don't know about the fitment but I do know that Andial has (had?) a midweight flywheel-about 18 lbs, as I recall.
Not sure if Andial is still in business....
chuck
chuck
Weathergirl
From what I've read here, the Andial MFW apparently solves the stalling problem on '95s, but is just as noisy as the LWF on which it is based. So far it seems to be the only alternative to a LWF, though. That's why I'm curious about a factory high performance DMF.
