Track pads?
Track pads?
I have been reading a ton of old posts about pads and I'm about to pull the trigger on some Pagid Yellows, but what do you 993 track rats use? Also, does anyone have experience with the Mintex race compound?
Thanks, Patrick
Thanks, Patrick
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
No experience with Mintex's track compounds. I do use, and continue to recommend PFC 97's. They are great pads, not too dusty and most importantly are consistent and give awesome pedal feel.
Hawk Blues. Cheaper than Pagids and far less fussy in terms of break-in and pad deposit. Dust is corrosive, so be sure to clean the wheels and car soon after getting back from the track.
The Pagid RS 14 black definitely has the most bite and best temp resistance. The Pagid RS 19 yellow, while not as aggressive can be used on the street w/ few problems(my choice)
the PFCs also have a very good rep
I like using the Pagid Yellow (RS19 I think it's called) in front and Pagid Black (RS14) in year..
FWIW: Randy Pobst drove my 993 and complimented my brake setup so I'll stick with what works for me...
Originally Posted by DJF1
I too run the Pagid blacks... hand of God braking forces but they are not too kind on the disks.
I'm using standard disks with Pagid Blues and ATE Super Blue Fluid. I've also removed the caliper backing plates to get some more air in there. They've so far survived some pretty heavy track work, including a stint with a very talented racing driver at the wheel and a trip to the Nordschliefe. They're kind with the disks and I've not had one second of fade, despite the car being a fairly heafty 3100lbs at the present.
Regards
Oliver
Regards
Oliver
