993 Forum 1995-1998
C2 vs C4 (or what are C4 negatives)
Old 09-02-2006, 06:22 PM
CarmG993
CarmG993's Avatar
i think the wide bodies are faster (did I say that )
Old 09-02-2006, 09:04 PM
kdurg
kdurg's Avatar
Originally Posted by TheOtherEric
I'm not going to touch this one either. But to learn more about the C2 vs C4 question, or narrow vs widebody, I'd suggest the following keyword searches:
1) racetrack advantage
2) 0-60 times
3) foul weather system
4) a**hole
5) talking out your ***
6) RWD fascists
ROFLMAO. Fabulous......
Old 09-02-2006, 09:11 PM
fast_freddy
fast_freddy's Avatar
Understeer/oversteer is all about throttle control and little more than that. Watch Mark Webber on TopGear driving that POS that Celebs drive on their track.Jeremy Clarkson said, "You didn't have understeer through the hammerhead", to which Mark Webber replied "thats because I know how to control the throttle".
Old 09-02-2006, 10:01 PM
Devinwhite
Devinwhite's Avatar
Default On a C4 or C4S you can disconnect the Viscous Coupling
I just purchased my first Porsche. 1996 993 C4S. When I took it for the PPI the
Porsche guy informed me the Viscous Coupling i.e. coupling that engages power to the front two axels was disconnected, thus the car drives like a C2S but is really a C4S. The car was purchesed out of Seattle and the owner had it disconnected because of the stop and go traffic as well as the "tracking" on the roads. He was upfront with me. Anyway I also took it to Rennsport
http://www.rennsportsystems.com (hight performance Porsche Shop) after the purchase to discuss. Apparently it dosn't hurt the car to drive it this way and can actually be better handling in "everyday" dry driving. He suggested leaving it that way unless I wanted the 4S "feel".
Hope that help
Old 09-02-2006, 10:09 PM
Devinwhite
Devinwhite's Avatar
Hope that help
Old 09-02-2006, 11:08 PM
JM993
JM993's Avatar
I'll put myself out there.
The negatives I've perceived about the C4, C4S and Turbo are the steering, clutch and shifter feel. They are all either too light and/or do not provide enough feel. IMHO, the C2 just provides more feedback and thus feels nicer.
That said, I've wouldn't kick any of there cars out of bed. They're all great!
Old 09-03-2006, 12:16 PM
mborkow
mborkow's Avatar
i am not sure how you lump the clutch of the TT, C4 and C4S together; the clutch feel of the turbo is completely different than the C4 (and i assume the C4S, though i have never driven a C4S).
Old 09-03-2006, 12:29 PM
robroy72
robroy72's Avatar
I've driven all three... C4/C4S are similar, TT is completely different, doesn't require as much force to operate it.
Old 09-03-2006, 12:49 PM
Svaha
Svaha's Avatar
Clutch job on a C4 is nearly $1k more, all labor...
Old 09-03-2006, 02:05 PM
JM993
JM993's Avatar
That's correct. I've driven all three and the feedback is less than the feedback provided by a C2. All great cars, just like the feel of the C2 more.
Still, I'd trade my car for the right turbo.......
Old 09-03-2006, 03:26 PM
Caveman
Caveman's Avatar
So with that soft clutch the Turbo is the girly option?
Old 09-03-2006, 04:07 PM
speed12sil
speed12sil's Avatar
You're kidding right? Because I thought the WB creates more drag at high speed so top speed is actually lower than that of the NB.
Jean
Jean's Avatar
I heard that the 993 C4 have 330Hp but the Porsche factory never recognized it. It is proven by the acceleration tests in some magazines. The C2 has the advantage of having a shorter gearbox by a couple of inches, which gives it better neutral handling. So it's somewhat a wash.
Old 09-03-2006, 09:30 PM
Droops83
Droops83's Avatar
HAHA. The 993tt uses the power steering pump to assist in clutch operation, like the hydroboost some 80s BMWs used for the brakes. Therefore, the clutch feels really light and rather vague while driving it. The shifter does feel vague on the TT for some reason too. If you sit in one and pump the clutch pedal a bunch while the car is switched off, bleeding off all the pressure in the accumulator, you will get a feel for how heavy the clutch would be w/out this system. The regular C4 does not have this, and the shifter feels a bit more precise too. The regular C4 does, however, use an electric pump/accumulator system to boost the brakes in lieu of the conventional vacuum booster of the C2.
As far as handling differences, Porsche vastly improved the AWD system for the 993 vs the 964. You have to push the car pretty damn hard to feel the difference between it and the C2. On the 964 you can feel the extra understeer pretty easily. I'd say for most drivers the C4 would be a safer option, although I would personally take the C2
Old 09-04-2006, 07:42 AM
Thaddeus
Deer Slayer
Thaddeus's Avatar
I like my 95 C4. I like being able to corner in the rain. I will like being able to drive a Porsche in January in Minnesota. Enough said.
Quick Reply: C2 vs C4 (or what are C4 negatives)
