993 Forum 1995-1998
dent in door that cant be removed??- help
Old 08-30-2006 | 10:01 AM
Rob 97 993c2's Avatar
Rob 97 993c2
Default dent in door that cant be removed??- help
i have a small dent in my right door about 8-12 inches below the right side view mirror. The dent is visiable, but the paint is not damaged at all.
My shop called a dent-removal guy who was unable to remove the dent due to whatever side impact bars are in the door. They even removed the mirror but couldnt get his tools in there.
Anything else i can do? this dent really bothers me.
Old 08-30-2006 | 10:25 AM
cabrio993's Avatar
cabrio993
Just get the iside door panels off and you'll have full access to the sheet metal, then you can pop the dent out from the inside.
Old 08-30-2006 | 12:12 PM
Arena993's Avatar
Arena993
DITTO. Remove the door panel and access is very easy
Old 08-30-2006 | 12:15 PM
911CabSteve's Avatar
911CabSteve
a GOOD dent guy can easily fix that.. Take it somewhere else.
Old 08-31-2006 | 12:07 AM
ceboyd's Avatar
ceboyd
actually, there are some spots the dent guys can't get to.. I happen to have one of the dings that can't be reached.. (regardless of removing the door panel because of the location)
...and the guy who tried to work on mine has been doing this for 20+ years and is well known by a lot of dealerships as the best around.. .he's taken out plenty of other dings for me where the end result if flawless!
Old 08-31-2006 | 12:14 AM
Crimson Nape Racing's Avatar
Crimson Nape Racing
Chris is right, I had one that could not be removed because of the protection bar. I had to have the door repainted.
Old 08-31-2006 | 01:24 AM
Rob 97 993c2
why does repainting the door remove the dent? how does the metal get pushed or pulled out?
Is there a protection bar below the side view mirror?
Old 08-31-2006 | 01:50 AM
ceboyd's Avatar
ceboyd
no.. the dent doesn't get taken out if the door is repainted.. it's called filler and sanding... (ever watch boyd coddington show where they use a ton of filler? ..that's the way the body shop does it... fill in, sand and re-paint)
Old 08-31-2006 | 03:38 AM
Wilder's Avatar
Wilder
I had the exact same dent and the first shop that saw it said the same thing. I took it to another shop and they hesitated for a while, then they found a way. If I recall correctly, they entered through the bottom of the door. Not an easy fix, but a true pro can get it done. Find another shop.
