993 Forum 1995-1998
Battery exploded !!!
Old Jan 18, 2009 | 05:12 AM
Kolbjorn S's Avatar
Kolbjorn S
2,5 years onwards - and today it happened again (3rd explosion in my 8 year of ownership), although not as severe as last time (leakage around all edges of battery).
Some facts;
- car sits alot (still), having use on average once a week
- everything works... runs well... nothing abnormal
- battery was replaced only 4 months ago. It is original Porsche 70Amp part no 999.611.070.20
- since the last explosion I have not used any trickle charger nor any other charger again
- vent hose was connected to the battery outlet, and looks to be open
Help!!
Old Jan 18, 2009 | 09:00 AM
Akerlie's Avatar
Akerlie
Hei Kolbjørn
This time go for a oddyssey 925 and the rennline brackets. That will make the explosions end
Old Jan 18, 2009 | 09:55 AM
murfysflaw's Avatar
murfysflaw
Wallflower
Dang... I've heard of it happening, but never seen it myself. Now I'm getting nervous about mine.
Old Jan 18, 2009 | 11:59 AM
Garth S's Avatar
Garth S
Some facts;
Help!!
Kal,
Consider repeating those DVM tests as in the first post ..... but test alternator voltage with the engine at ~3000rpm in addition to when at idle: it still looks as if you are getting a considerable overcharge = excessive hydrogen = boom! ( also, flip to AC as noted in my other post, and check stator plate diode health).
Anyway, it still sounds as if the regulator isn't doing its job: fairly easy to pull the alt., and replace the regulator/brush holder assembly.
grwoolf's Avatar
grwoolf
Were all 3 explosions with Porsche batteries? I think I would try another brand. While is sounds like something else must be contributing, these Porsche batteries might be less tolerant of overcharge,and particularly heat(made in germany?). I believe Muscat is one of the hottest places in the world and maybe there are better batteries for that climate. I've never had a problem with exploding batteries in Texas (also very hot), but the heat can kill a battery just as fast as the cold. I've seen several people try to quickly charge old batteries with a charger and you can hear the acid boiling, but I've never seen one explode or crack. If the battery is vented, there shouldn't be any pressure. I would check the charging system again to make sure the alternator isn't cooking the battery and I would absolutely try another brand of battery.
Old Jan 20, 2009 | 12:16 AM
troppo's Avatar
troppo
used odyssey batteries for a few years and it is nice to not have to worry about these issues! Highly recommended and save some weight while you're at it!
Old Jan 20, 2009 | 11:32 AM
catalinajerry's Avatar
catalinajerry
Default Battery explode
I have an 04 Turbo and my Porsche battery also exploded. Also don't drive it much (10000 miles in 5 years) and wasn't covered under warrenty as car must be driven 7500 miles per year for battery warrenty. I have noted that the new Porsche battery was low on water after several months of non driving so now I check it monthly and fill with distilled water. I also use a Porsche trickle charger. There seems to be a common thread. Porsche battery, low useage and trickle charger. Hope this solves the problem.
Old Aug 29, 2010 | 11:20 AM
dhicks's Avatar
dhicks
Default Me Too!!!!!
I thought to myself, I have just passed emissions, the car needs a good clean and maybe I will go for a drive, it is afterall a nice day. Open garage, get in car...turn ignition...kaboom!!! WTF was that.....after about 2-3 minutes worked out the sound came from front...opened bonnet, SMELL....arrgggghhhhh battery acid.....looked - top blown out of battery so not too much acid, but removed battery and dumped a box of baking soda into battery tray and leaving for now to do its work! So question to myself, do I just get a new battery and install or do I get the electrics checked first.......Taylor Chapman at German Auto Group, the best Porsche guy I have ever had the pleasure of working on my Porsche will be getting a call to check it all out before I do any more....but what a shock...hope it is just the battery and nothing else!!!
For those that are going to ask question
Battery was about 4 years old
Battery is maintained on a Porsche battery maintainer
Car is only driven every month or so in summer
Old Aug 29, 2010 | 11:55 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Don't forget to douse it well with baking soda and water. Sorry to hear about this. I've never seen it happen but can imagine it's pretty frightening/messy. Good luck.
Old Aug 29, 2010 | 12:04 PM
tjangi's Avatar
tjangi
i am glad that no one got hurt.
On another note, I had the same battery for 7 years, no tender during the winter and the battery still runs strong. What is the average life on these things? Good time to upgrade to an optima? Do I need to hook it up to a tender if i do? Sorry for hijacking the thread. TIA
Old Aug 29, 2010 | 12:58 PM
johnsjmc's Avatar
johnsjmc
I have never used a battery maintainer, but frequently use a regular battery charger. When it is disconnected is there a chance for a stray spark under the closed hood? Do you unplug it at the wall plug first? Batteries normally release hydrogen gas which is why they can explode. I have seen this in a garage where all the used batteries were in a pile near the back wall and a spark from welding nearby blew one up. Very messy and the thought of being doused in sulphuric acid is scary.
Old Aug 29, 2010 | 01:18 PM
dryadsdad's Avatar
dryadsdad
Team Owner
I had a motorcycle battery explode like the OP describes. Blew acid all over my face, hands and clothes. Luckily I was at a bike shop which was prepared for an acid explosion so I got myself and my clothes neutralized pretty quickly.
I never had any injuries to my body, but a few days later the clothes I was wearing just fell apart. I guess the acid got in the cloth beyond the ability of the baking soda to neutralize.
Old Aug 29, 2010 | 02:39 PM
swmic's Avatar
swmic
I saw one explode several years ago in a neighbour's jeep. The hydrogen gas from this things can be very dangerous. When pulling the terminals or charging a wet cell, I always make sure it's well ventilated. Seeing one explode will leave a lasting impression.
Old Aug 29, 2010 | 04:28 PM
Bruce P's Avatar
Bruce P
I had the same thing happen with 2006 997 Carrera S. Car was on a Porsche battery tender and when I went to start it the battery exploded. However, not much acid. Conclusion was the battery tender boiled the battery nearly dry so what was left in the battery was a lot of hydrogen gas. When I bought new battery at the dealer I was told that they had sold new batteries to several people that had experienced explosions. They sold me a "better" Porsche battery tender but now I just disconnect battery if it is going to sit for an extended period of time.
Old Aug 29, 2010 | 05:42 PM
Allen's Avatar
Allen
Is this a pressure inside the battey build up issue...in which case an unclogged vent tube would eliminate? Or is this a water in the battery got low/empty leaving an explosive gas??
Mine is a Sears Die-Hard that I installed 2/2002 (over 8.5 years ago). It is on a Deltran battery tender when it is not being driven...once a month or so. No problems so far...cranks like it's brand new. But what do I need to be checking to prevent this...water level in the battery cells??
