Rear window rubber replacement
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Just back from collecting the car after having the outer rubber gasket replaced. Thank for the various responses. However I had to go the new window route. The old one came out ok but the factory glued-on/ bonded rim was shot. Also found some rust starting in the groove around the window opening so that needed to be sorted by OPC before they put in the new screen. What was really a cosmetic fix became expensive (approx $1250) but it would have bugged me to know that a quick fix job was done. Don't plan on being parted any time soon!
Apparently 996 onwards have a removable rim.
Thanks once again for the helpful advice.
TT
TT
TT
TT
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
It was light rust not yet pitting into the metal. It was in the channel that the inner gasket fits into. I had rust around windscreen issues on my '84 3.2 also This is apparently fairly common on 993 too.
Pity that being an '94 it's out of 10 year rust warranty.
rust in cape town? I wouldn't usually expect that however you are in a marine climate, no?
Either way, glad to hear it's fixed! And think about it - it's been done right. Money well spent?
Originally Posted by g_murray
Whereabouts was the rust ....?
I noticed my rubber has 'shrunk' down at the corners and tends to collect pooled water there - after I wash it.
G.
G.
I notice water collecting there on mine too. I have taken to blowing out the pooled water after washing it. Think I am going to start using a hairdryer to dry it as well. Could it be I am obsessed with this car?
I bought a tube of 3M 'window sealer' (emphasis on SEALER rather than glue) and plan on 'filling my corners' with it. Got it on ebay for 15 bucks plus shipping.
G.
Keep in mind that using sealer in just the bottom of that channel might result in water still leaking in from the area above it and really staying there.
What I've used on Mercedes vehicles, though not on any Porsches yet is 3M Bedding and Glazing Compound part# 08509. If you're interested do an internet seach on product. It has good properties and is used between winshield rubber and car body, it remains soft and pliable. I've used it with great success resealing the rear cargo windows on Mercedes 124 wagon.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Odometer was altered to kms when it arrived here and now has 40k on new clock. Total 56k kms. Needs more use but don't like useing for short trips.
thanks for the info.
So you are using it as another sealer underneath the rubber seal?
For example if you replace a side window on a Porsche you will run a bead of that stuff inside the channel of the gasket and then put the glass in the gasket. If there was a problem with a leak where the gasket goes into the actual car I may put some there too after the cause of the leak was repaired.
On the Merecedes windows in the cargo area I put it in the gasket and then run a bead around the perimeter of the window frame before I put the gasket with the window in the car.
I've not had or seen a front or rear window out in a Porsche so I'm not sure how I'd handle that. I would not be inclined to use any product to fill an area that was rusted already. I'd fix that first.
I would think I'd do the install the same way I have done it on MBs and on the Porsche side windows.
Originally Posted by AOW162435
Technical Guru
front and rear window are both supposed to be sealed after installation but nobody ever does
If I used my car alot or drove in the rain I'd give serious thought to filling the void with 3M bedding compound.
I try to dry under that area when I wash my car by putting a paper towels under that area to remove water, I've done like Paul906 has also with compressed air.
