Where is Fan belt warning light sensor?
Same issue but fan belt light wont come off
Hello all, in desprate need off anyone support! I’ve changed the belt sensor and still my light wont come off, ive checked the microswitch and its giving a positive signal when pressed so signal seams to be sent somewhere but the light on my dash doenst goes off. Car is 911 mod 1995
- I would check in the owner's manual as to what the meaning is and the various sources that may illuminate the light. Also
- I suspect if you run the OBD Codes it may give you some insight into the cause of the light.
- Having verified that the warning light is related to the belt sensor I would also take the sensor switch wires and short them out with a paper clip and see if the light goes out.
Andy
It came out to something to do with the vdo unit under the dash, sprayed it some contact cleaner pluged it correctly all off except now rear apoiler light is on.... along with the airbag light
