993 Forum 1995-1998
Squeaky, sticky clutch
Old Jun 15, 2006 | 01:28 AM
jnnking's Avatar
jnnking
Originally Posted by JasonAndreas
When you were bleeding the slave cylinder did you operate the clutch pedal at all?
No, not while bleeding. At the suggestion of Robin? (quoting from the manual, IIRC), I did try bleeding it with the pedal depressed. I ended up with the same result.
Old Jun 15, 2006 | 02:28 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Originally Posted by rdurff
I had my mechanic check it out (reputable air-cooled-only shop in Seattle) and his analysis was that it was the nylon bushings making a bit of noise in the pedal cluster
The bushings are Teflon and if squeaking the "bearing and sliding surfaces" can be lubricated with a Teflon-compatible low temperature grease such as Glissandro from Texaco.
That comes from the 996 manual but one of the warnings in the 993 manual (but in relation to bleeding the brake master cylinder and not the clutch so I'm not sure if it really applies) is to only use half the cylinder stroke on older or high mileage vehicles or you damage the cylinder. Which is something that has been reported here a few times. The other warnings are don't lubricate the clutch master or slave cylinder plunger and when you replace the master cylinder to set the clutch pedal travel to 150 +- 5mm.
good luck!
Old Jun 16, 2006 | 09:34 PM
jnnking's Avatar
jnnking
I can't buy a break. I was supposed to have a new master here Thursday. Pelican shipped it Ground instead of Next Day. So I called and ask them to ship one for Next Day AM, Friday morning. They ship it standard Next Day and it gets here friday afternoon (today). I install it and get the pedal cluster re-installed. The clutch was depressed in order to attach the cylinder. When I pull the pedal forward, the return spring snaps in three places!! I didn't pull hard, so I'm confused as to why it would have broken.
After an afternoon of phone calls, I can not find a spring anywhere in North America. It looks like I'll be missing my DE on Wednesday as I wait for one from Germany.
If any one has a lead on the part, 964-423-551-02, I'm in need
Old Jun 17, 2006 | 01:41 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Jim,
If you get into a bind, I have a brand new clutch master at home. I arrive home Sunday night, I can ship it out to you Monday. Let me know..
Old Jun 17, 2006 | 10:58 AM
jnnking's Avatar
jnnking
Chris,
Thank you for the offer. That's what I love about this place. What I need is the clutch return spring. The master I have is good and have the first one that was shipped ground arriving on Tuesday.
Old Jun 23, 2006 | 07:06 PM
jnnking's Avatar
jnnking
It's been too long without my ride. I ended up getting the spring from DC Auto. It's the only place in North America I could find on. Thanks for the help guys!!
It arrived about 90 minutes ago. I finished installing it, bleed the system and I've got a nice, smooth clutch again. And I can drive my car.
What a headache the whole process was. But now I've got all my components and I've learned much from the process.
Back in a few hours, I've got some roads that missed me....
