Documented HP gains/loss with straight exhaust?
Anyone out there dynoed their car with a cat only and then run it with cat bypasses? I have a dyno sheet from my car with cats and "supercups" i.e. no baffles. Just wondering whether I will help or hurt myself running cat bypasses and baffle-less exhaust pipes. It sounds faster ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Do straight exhausts cause a gain or loss of HP and/or torque?
And yes I did a search but I am not sure I constructed the search terms appropriately bcause I am sure this has been discussed here.
If you decrease exhaust backpressure you should get an increase in top end HP, but a decrease in low-end torque. Generally. No dyno numbers for my recent bypass install, but the butt-dyno seems to agree.
Originally Posted by Mark in Baltimore
John,
I thought I had read here that bypasses, while sounding great, take away from hp and/or torque.
Originally Posted by pcar964
"shall I turn it up?"
I am doing it as hard as I can.
Mark/Chris
That's what I thought I remembered. I am going to a NASA event next weekend. I may put it on the dyno just to see. I have a baseline with just cats and the rest straight thru. Right now, as the car sits, it is straight thru all the way. It would be interesting to finally know for sure. God knows I can't afford to lose any torque as slow as I am thru the corners.
The January 2006 "911 and Porsche World" magazine had an article on a 964 where the owner removed the cat and the shop that did it dyno'd a 15 horsepower increase. Would likely be similar with the 993.
