Engine rebuild cost ( Viper Bob )
Is this a reasonable qoute?
While they are in there......?
When they are doing the rebuild what can be done to make it a little better without major costs??
Estimate cost engine rebuild
1 Set of cilinder head gaskets 433,16 433,16
1 Set of piston bounces 117,39 117,39
1 Set of crank shaft bearings 207,93 207,93
1 Set of engine gaskets 62,58 62,58
6 Bearings traction rods 25,31 151,66
1 Crank shaft pulley 2824,86 2824,86
1 Bolt 2,58 2,58
1 Pulley 164,61 164,61
1 Pin 0,4 0,4
2 Belts 8,85 17,7
1 Belt 12,57 12,57
1 Sender belt 45,09 45,09
4 Bolts 5,8 23,2
2 Gaskets 7,89 15,78
1 support 35,65 35,65
22 Mobil 1 7,21 158,62
4 Cleaner 3,8 15,2
4288,98
46 Labor 54 2484
Without taxes Total 6772,98
1 Bolt 2,58 2,58
1 Pin 0,4 0,4
2 Belts 8,85 17,7
1 Belt 12,57 12,57
4 Bolts 5,8 23,2
4 Cleaner 3,8 15,2
4288,98
46 Labor 54 2484
If that was $ incl tax, it's about right. If Euros without tax, it's probably still about right, given that almost everything in Europe costs in Euros what the dollar amount would be here. I would add while you are in there:
a set of spark plug wires
a new SAI one-way check valve
LWF/RS clutch if you don't already have one
I don't think he needs a SAI one-way valve given he is in Europe?
I commented on the prices in your other thread...why split the threads?
Cheers,
Mike
Cheers,
Mike
