Help from Hartford (Ellington), CT area??
There's an iris blue cab on ebay that caught my eye:
http://cgi.ebay.com/ebaymotors/RARE-...QQcmdZViewItem
Anyone in the Hartford area know this car or interested in checking it out for me? If so, please email me.
Much appreciated,
Kevin
Much appreciated,
Kevin
At first glance, I noticed the spoiler wall needs to be replaced. The seats might look a little tough, some good scuffs next to the driver seat controlers. I would also ask for some more closer up pictures of the top and the rest of the car.
Last picture on the second row. You should not be able to see through the rubber wall. it should block the air from passing through entire;y.
Replacemetn part is about $85-$100 depending on source and depending on skills can be doen at home.
Originally Posted by kpieper
Also, can anyone make a recommendation for a good PPI in the area?
thanks in advance,
Kevin
thanks in advance,
Kevin
He is very active in PCA. Another shop that is about 45 minutes from Hartford is Hairy Dog Garage. Both are very high quality shops.
While I haven't had work done by either of these shops, (Dan Jacobs @ Hairy was recommended but at capacity when I needed a PPI, so Farnbacher did it, also excellent) I have heard both are very good.
Saw them in action at a PCA event recently and you should be confident that they are disciples of Porsche.
Good luck!
Good luck!
Originally Posted by mo
Right in the area is Chris Mustante. www.MusanteMotorsports.com
Sorry I did not read this thread earlier, but perhaps the car has not sold. Ellington is quite close to Chris Musante's shop on route 5.... maybe 20-30 minutes tops.
Chris has done some work for me last fall. Installed Gert's M030s/HD Bilsteins/FEP... did plug change out and 4 corner balancing. I'm pleased with his work... altho not the least expensive job I have had done. But, that said, Chris is a good guy and would do you well.
Give him a ring if you want the car looked at...860-291-9415.
Also, Tony's Imported Auto in Manchester is good as well. Just had some work done there as well. Tony used to work for a Porsche dealer before opening his own shop. I like him and his son.... again, good folks. Again, maybe 30 minutes from Ellington, CT.
Here's their number, too... 860-649-6094
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
