Can't believe I am saying this, my 911's A/C is freezing cold!!!!
#31
Originally Posted by Robin 993DX
oh............. Forgot to mention....I was referring to my 996.
My 993's A/C still sucks big time.
My Chevy's A/C works real good too.
#34
Thanks Robin. What led you to that?
Some background on my problem- the compressor cycles on/off every 30 sec or so. When it's running it blows cold. But it seems like it could be much better if the compressor stayed on longer. The low speed condenser fan is working (after I changed the resistor) and the high/low side pressures are ok (225/15psi @ 2k rpm @70F). I'm about to check which switch is causing the compressor to turn off, ie three level pressure switch or evaporator temp sender.
Pete
Pete
#36
Pete
Pete
#38
#39
Resurrecting a really old thread here.
So if I summarize correctly, if the compressor is cycling on and off too swiftly:
A) Check there isn't too much or too little pressure on the low side, or ideally both sides with an A/C Manifold
B) Take out the CCU from the dash and clean it throughly (referring to back contacts and fan and all that)
C) Consider expansion valve replacement
Do I have that about right?
