Have you looked at the little trailers from Harbor Freight? Some may laugh, but for the money you can't beat these guys. With a little DIY you should be ready to go for a couple of hundred bucks.
I have the da'lan 993 hitch--it's actually very elegant in how it mounts on the rear tow hook and bumperettes. I'll gladly sell it for $200 plus shipping, including the 1 7/8 ball, which would add another $25 or so on top of the $330 it cost.
I guess it does not work if you have deleted the bumperettes?
Cheers,
Mike
I guess that depends on whether you can still access (or still have) the metal mounting points that are behind the bumperette. To mount the hitch, you drill a hole into the center of each of those metal mounting points and attach the hitch to those points (in addition to the big bolt that goes behind the plate).
I have a friend with just the trailer for you. I bought it from Kim Ouye, but never used it as I went to a full open (now a closed) trailer. He bought it from me intending to use it to haul his tires for autox. It's been sitting in his driveway since.
