993 Forum 1995-1998
Top end rebuild estimate, Is this reasonable?
Old 05-01-2006, 01:54 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Originally Posted by ceboyd
so am I hearing a consenus that a top end rebuild is to be expected by about 90K miles?
I feel it all depends on many things to set a target mileage when engine work will be required.
I say this because I have seen many low mileage cars needing guides, and high mileage cars running well with minimal or no oil consumption troubles. Such required work seems to be all over the map in terms of mileage alone.
Old 05-01-2006, 02:27 AM
ceboyd
ceboyd's Avatar
that's what I figured because eric's former 993 never ate any oil, never leaked, etc. and ran strong even when over 100k miles
Old 05-01-2006, 11:13 AM
fast_freddy
fast_freddy's Avatar
Originally Posted by SR71BLACKBIRD
Sorry to hear about that Freddy; that was so sudden. Do you have your engine tray off and is most of your driving in the city in rush hour? I think I will do the Hi speed oil fan cooler as soon as I can to do some preventative measures - btw - did you do that too?
Scott
Engine tray is off, Oil cooler fan is set to "11". Most of my driving is to and from work
8 miles each direction about 1/2 of which is on the highway the other half stop sign/light hell then "nirvana" with the throttle between them (if you know what I mean.... and I'm sure you do). Virtually no rush hour oriented driving (well for some Vermonters it might be considered rush hour - I'm a "flatlander")This past weekend I drove about 400 relatively hard miles through the mountains and ate absolutely no oil. Now I am totally perplexed, perhaps with all of the talk of worn exhaust valve guides on 993/964's I've been suitably brainwashed into thinking it needs to be taken care of.
Old 05-01-2006, 12:04 PM
ceboyd
ceboyd's Avatar
..the plot thickens!
Old 05-01-2006, 12:29 PM
Rick Lee
Rick Lee's Avatar
You have a lot more diagnosis work to do before tearing down the engine.
Old 05-01-2006, 01:21 PM
ZombiePorsche44
ZombiePorsche44's Avatar
A serious +1 on what rick lee said ! .....keep us informed on new developments......Good Luck!
ZP44
Old 05-03-2006, 07:38 PM
JPS
JPS's Avatar
So what sort of oil consumption is a target that you may need to consider a top end rebuild? I have 118k, track it a fair amount (percentage wise, low miles each year overall), and burn maybe 800 miles but each of those quarts also include track time. Oh, and I replaced original clutch at 95k miles. First 70k miles of car were SoCal freeway driving to the Porsche dealer that owned the car.
Old 05-03-2006, 10:10 PM
Rick Lee
Rick Lee's Avatar
JPS, I'd start a fund for the rebuild if I were you. But I'd keep driving it until the rebuild has to be done. You ain't there yet, but it will come.
Quick Reply: Top end rebuild estimate, Is this reasonable?
