Heads Up! DME Relay failures......
The guy who bought my TT had his DME relay fail last weekend at a track. Luckily his friend was finished for the day and loaned him the one from his car.
I've now seen this happen to several friends and usually at the track.
So take heed, and carry that spare. They're about $33. from Porsche.....
i know... i'm off to get one for the glove box. this is my second warning from you jrg. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
that 1st story was pff!
i'm spoiled... the 993 starts up any time, any place, any temp.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
King of Cool
Originally Posted by Marv
How do you know when it fails? What are the symptoms? Won't crank, won't run. etc.?
I changed mine (years ago) with the 993 part and put the old part (that still worked) in the glovebox.
$25 at Sunset with the Excellence discount (cost + 15% + actual shipping).
When I got my new one, I installed it and put the older one (still working) in the box as my backup.
My mechanic said if it fails just pull it out and bounce it on the ground once then reinstall.
I bot a new one for the glove box just in case this highly technical manoever (like the bucking bronco seat un-jam technique) doesn't work.
Super Duper Moderator
Originally Posted by ecobb993
I posted this question on other similar threads without response:
Is anyone experiencing failure of the 993. part no. dme, or just the earlier 944. part no?
Yes, 993 p/n DME relays can fail too.
Marc
