RS Rear Sway Bar Link BROKE - NO TRACK FOR ME this weekend :(
Originally Posted by Greg Fishman
you should buy a set then use the "old" one that is still intact as a spare.
BTW, I attribute this to both the drop link mount to the shock and the TRG sway bar on my car. I think the TRG rear bar needs to be a little wider (longer from left to right), plus you have to make sure you have it perfectly centered since the collars aren't welded. On one occasion, the drop link broke in the same exact manner when the drop link holder on the shock got loose and twisted around, like you mention.
George
Darth Cup
I had these on my 993 race car for 5 years and never broke one. Maybe I got a "good" set or maybe it was something related to how it connected to the shock?
One thing to check is does your swaybar move? We installed mine when we were building the car and found out we had the wrong bushings so the bar was virtually fixed, this would have caused issues with the handling and the links.
Thats good to hear, makes me feel better about the link design, have heard about these things failing (pic from Robin's site):
I have the TRG sway bars and custom H&R/ROOCK (or is it ROOK?) coilovers with -3 camber in front and rear.
Yes, my sway bars have room to move up and down.
Yes, my left rear support got loose and is probably what caused it in my case as we tightened it back up at the track.
I'd prefer NOT to have another set of these RS since they have an obvious weakness with that stupid plastic and would rather have the befier ones with really ball joint (much like the spherical bearings).
I will wait to see if I must buy a pair or not and if I have to spend more just to get through the weekend or if Eric *(my eric) can custom make me some in time for next weekend or not (he custom made some for his race sentra that are darn nice with the realy bearings instead of that pressed in plastic crap on the RS one)
Ultimately I'm hoping I don't have to invest in more RS links but I'm in a bit of a time crunch needing something for my 2 day weekend... after that I have time on my hands since I won't have another event until May 20th after next weekend.
Thanks guys for the insight.
If I were to stick with RS end links for sure, I will (of course) buy a pair and keep the old one for a spare back up!
Originally Posted by ceboyd
... Yes, my left rear support got loose and is probably what caused it in my case as we tightened it back up at the track.
I'd prefer NOT to have another set of these RS since they have an obvious weakness with that stupid plastic...
I can assure you that installation was NOT an issue. Eric knows what he is doing with suspension installation.
Eric, I think you missed the post about how in my case I believe it was due to the loosening of the mount on the strut and 2 other people confirmed that this indeed can cause this to happen.
Nevertheless, it is still a weak point (come on, PLASTIC?) that I don't want to trust in the future!
I got 2 years and 40+ track days out of them so I guess in that respect I should be happy...
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
It basicly means another thing to check after every track event... bolts loosen and in this case, somehow the mount loosened on the strut itself.. it wasn't loose when installed.. and it wasn't loose when the alignment was checked just a month earlier..
vibration and track use can cause loosening.. it doesn't necessarily have anything at all to do with installation IMHO
and FWIW: I would have rather it BROKE and have to be rewelded (as there was a weld shop on site at the track) (broke like in the photo showing the weld).... which I believe is what would have happened if the plastic didn't break... thus I have little faith in a plastic part on something that endures so much stress like suspension...
Several issues really ...
So you are well off the design envelope for the drop links ... stiffer bars = greater load on drop links ..
If they are installed tight, but with load angles trying to loosen the mount, you will be in trouble sooner ot later.
The situation I was attempting to highlight was the mount moving far enough that the drop link made contact with one or other control arms. If you had a really beefy drop link you might end up breaking one of the control arms under suspension movements, instead of the plastic bits.
Which would you prefer ?
Anyway, you're OK, so reflect and get back out there !!
cheers, Maurice
cheers, Maurice
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
how much stronger are the TRG sway bars from the RS bars anyway on the loosest setting? (which is what I had them set at).... does anyone know?
Sounds like we're saying the same thing: the drop link mount somehow got rotated, causing a side load on the drop link, which tore it apart. That alone wouldn't deter me from buying RS drop links. In fact, it's a good thing that your link broke before your mount did (which I understand is what often happens when the mount gets rotated). FWIW, my rear mounts started rotating last summer too, just due to loosening over time. I totally agree that the vibration and shock has a way of loosening these so we all need to be aware.
alrighty then.. curious though cause I guess I made a false assumption that the TRG bars are the same as the RS sway bars... just cheaper... IIRC the RS Sway bars will set you back over $1g where as the TRG sway bars only set you back around $650 (or did I remember it wrong?)
One more thing on this topic: most people don't realize that the PSS9/TRG setup (and probably many other setups) cause the rear drop link to put a load on the drop link mount that is not purely up/down. Thus, the load isn't perpendicular to the threads on the shock body, but instead has a side-to-side component in the direction of the threads, which often causes the mounts to loosen up, then rotate. That's why I put a nut both above & below my drop link mount.
p.s. doesn't your car push a lot with the rears on the loosest setting??
