Cheap horsepower...
Just for grins
I built a spreadsheet to figure how much weight I'd have to pull from my car to get to 300 "effective" horsepower.
Curb weight divided by horsepower yields the power to weight ratio and so yields the horsepower effectively added (I think). Each incremental weight loss requires less subsequent weight loss to gain additional effective horsepower.
I'd like to pull an additional 60 lbs or so to get to the effective number up to 300.
An alternative is to spend $10K or so for the 3.8 upgrade
, but weight loss is so much cheaper.
Any ideas? What have you guys done?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
You can save a LOT of weight (I don't have an exact number) by replacing the stock power seats with lightweight seats, replacing the rear seats and panels with RS carpeting, and replacing the front door panels with RS panels. Then replace the stock mufflers and cats with pipes and Fabspeed Supercup exhaust, and strip the trunk down to the bare essentials, getting rid of the cover.
Now that I have looked at your spread sheet, I see you have done some of the above. Did you weigh your car to begin with, or have you weighed it now? Porsche published weights are "interesting, if true" for any particular car. One weight doesn't fit all examples of a model, with all of the option combos possible, of course. Most Club Racers in the Stock classes have to add lead weights to make the minimum weights, even after installing roll cages, etc. Not that it will make a huge difference, but if you are going to the effort to make such a spread sheet, you probably want to start with accurate numbers.
My C2S, when it was factory original, weighed almost 80lbs less than the published weight.....with a full tank of gas.
Bob W. -
I did not weigh the car when it was stock but, now that you point it out, I bet mine weighed less than the published weight as it was a lightly optioned car when new. Where does one go to have their car weighed. I'd like to know the real number.
I can definately notice a difference in acceleration from the ~125 lb weight reduction thus far. Handling seems improved as well.
Ron
Ron
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
An old rule of thumb the drag racers use(d) is 100lb reduction is worth a tenth of a second in the 1/4 mile..
Aero improvements (drag reduction) is more complicated as its a speed-squared law, but super interesting nonetheless..
I'm in violent agreement - adding lightness is the best performance improvement you can make to a car. Less mass to brake, turn and accellerate. It also helps if you can remove mass with excess polar movement (ends of the car), and why club racers adding weight get to place low in the middle.
I'm stripping mine fairly aggressively. Important stuff like AC stays, but unimportant stuff like the sunroof goes. The interior sound deadening and panels are heavy. Here's a partial guess/SWAG at some of my net losses (I'm not building a precise weight spreadsheet, because in the end only the net number matters):
RS Carpet Kit, Al floor panels, RS Door Panels - Interior Sound deadening, rear stuff, carpets, etc = Net -65#
Sparco Seats - stock power seats = Net -70#
Momo Mod 07 - two airbags = Net -9#
Cat bypass, engine tray, sound pad and Wevo motor mounts = Net -30#
Sunroof = Net -30#
RS Washer Bottle, excess fluid = Net -20#
Foglights = Net -5#
Battery = Net -20#
RS heater bypass - blower stuff = Net -10#
Trunk: Spare tire, carpet, tools, etc. = Net -36#
So the thumbnail total is about 295#. But, this is offset by a half-cage, fire supression, heavier suspension bits. The proof will be when I c/b the car and find out what the final net weight will be.
If you pick up the hood without the hood struts, you'll be floored at how heavy that piece of sheet metal is. So long-term, a little bit of fiberglass here and there, lighter wheels, etc. and you can see how a Cup car weighs about 2,500#
Hopefully, I can get in the 2800# range, or about 100 more than a factory RS.
Sunroof = Net -30#
Foglights = Net -5#
Battery = Net -20#
Loosing weight is a noticeable improvement in the car's capabilities that are not just limited to increased acceleration. You also get the added benefit of faster braking and better cornering. Some may argue about weight biases that may be introduced so you should take note on where you are removing the weight (front vs. back and how high in the car).
I have kept a detailed spreadsheet of my car. if anyone wants it let me know...
cheers,
boris
cheers,
boris
Originally Posted by rav
Bob W. -
Ron
Ron
Hey Don -
Tradeoffs for a low mileage "polisher":
gotta stay:
door panels (my wife likes to ride in the car)
sunroof (no die grinders within 50 feet of my car)
tools & spare tire (might get a flat while wine tasting in Santa Ynez)
gonna go:
washer bottle, 20 lbs
trunk carpet, 5 lbs
Thanks,
Ron
gotta stay:
gonna go:
trunk carpet, 5 lbs
Thanks,
Ron
Sunroof = Net -30#
Foglights = Net -5#
Battery = Net -20#
Sunroof = Net -30#
Foglights = Net -5#
Battery = Net -20#
......Hopefully, I can get in the 2800# range, or about 100 more than a factory RS.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
