what is that knot from 2nd to 3rd
Originally Posted by brucec59
Only trouble is, by the time you wait for it to go in, the engine is spinning too slowly to match revs without getting on the gas a bit.
Originally Posted by mrsullivan
exactly!!!! i end up blipping throttle to rev match during upshifting for this reason lately
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Now the blipping on th e upshift is interesting...I do not at all. I feel the syncros as they line up and then it slips very easily into gear. But...the revs do not fall off; it is perfect for the next gear. This doesn't sound like a fast shift deal...more like worn syncros.
Hmmm
Hmmm
Sorry, old thread, but as a new manual 993 owner I've also noticed the slight notchniess from 2nd to 3rd. If I shift slowly, it's usually not there, but quick shifts can generate the gear meshing sensation. Good to know -- sort of -- that's it's 'normal'.
I just had my 968 fixed for a similar issue (same tranny). Pointer: If you have to replace the synchro hub, order from Sunset and have them look up the part number under Audi - it's half the price.
There is an adjustment eccentric on the forward left side of the G65/G50 case that impinges on the primary shift rod: it is my supposition that its function is to affect the shift quality ..... but I cannot advise on the correct adjustment technique. When reassembling my spare, the trans was bolted to a shifter assembly, and I played with the eccentric until the shifts " felt right" ..... that's as scientific as it got!
Perhaps someone capable can advise if any of this is meaningful ......
