I'm thinking of doing a DIY muffler change. Once the car is raised using a trolley jack under the engine. Where do you put the axle stands to keep it there assuming I don't trust my trolley jack with my life?
Also there seems to be some concern about jacking the car under the engine. After the sound tray is removed has anyone got an exact picture of where to put the trolley jack?
Thanks.
Reason: more added
You may also want to put a rubber pad (some use a hockey puck) on the jack. That'll give it a little more grip, rather than metal sliding against metal.
When you are taking the exhausts out, you may want to remove the wheels, it just gives you more area to work on. That might be obvious, but the first time I did it, I left the wheels on and it was a pain!
Also make sure and wear some eye protection, a lot of junk is going to fall on you as a lot of dirt, rocks etc. gathers on in that area.
Hmmm, just curious, Mike. What's your opposition to the hockey puck at the engine case? It's hard enough to keep its shape, and by nature non-slip and non-marring. Am I missing something?
Hey, do whatever you feel comfortable with. This has been a MUCH discussed topic on Rennlist in the past. Read the threads and then do what you think is best for your car.
Problem is I've only got one trolley jack and if I don't jack it under the engine, it's going to be interesting trying to make (safe) use of the jack and the axle stands.
I was thinking of using the hockey puck and a block of wood, just to keep everyone happy
I think I'll just take the chance and lift it via the engine.
Steve - Yes it is Northway. I bought it from a guy who had it on 'sale or return'. I used to get my C4 serviced there..what Ray doesn't know about 993's isn't worth knowing.
I feel a bit guilty now though as I get mt TT serviced at Porsche as I want to keep the FPSH going. But it does need new heat shields so I'll get them done at Northways, just to keep him happy. (plus he's half the price )
