wheel lock lost by repair shop!! What now??
I took my car in for an oil change last fall b4 I layed her up for the winter. Yesterday I went to pull the wheels in prep for painting my calipers per advise from the guys here at the forum and... No removal tool!!! They are after market OZ rims. Any advise. thanks
If they are still the factory wheel locks, the dealers, and potentially a local independent shop, will have a set of wheel lock masters. There are only 45 locks, so it just takes a little trial on error to get the right one and to get yours off. This will also tell you the key number then that you can use to contact McGard to get a new key. In the mean time, just have the shop that removes them install 4 regular lug nuts.
Passed On
I had this problem with a BMW years ago, so I went to a couple of shops who were suppose to have the right tool to remove. It ended up being a size 19 socked that got pounded onto the wheel lock and then removed. If I had not seen it done I would not have believed it. Do not unless it is last resort let someone drill holes threw lock to weaken and removed I can not tell you how many wheels have been ruined this way. Good luck! Jim
I had this problem with a BMW years ago, so I went to a couple of shops who were suppose to have the right tool to remove. It ended up being a size 19 socked that got pounded onto the wheel lock and then removed. If I had not seen it done I would not have believed it. Do not unless it is last resort let someone drill holes through the lock to weaken and removed I can not tell you how many wheels have been ruined this way. Good luck! Jim
I went to the dealer who had a box with all the "keys" and just kept trying til I found the right one. I removed the 4 locks and bought 4 plain ole lug nuts.
