European Rennlisters- is it required to have the rear wiper?
I am thinking of deleting the rear wiper because I never use it and I prefer the cleaner look of the wiper delete option.
I just need to make sure this is not a requirement to have on the car in Germany. I don't want to pull it off only to find out it is required to pass inspection on German roads.
Either way, I'll be fine.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Hey! Also, I am going to remove the basket handle and have a body shop fill the holes and paint the decklid. I am planning on buying a '96+ window mount third brake light and having it painted and installed at the same time. Do you fellas see any problems arising from having a '95 model with a '96+ third brake light?
Just curious.
TIA,
Lee
Just curious.
TIA,
Lee
Hi Leland,
Not sure about German requirements but it is not required here in the Uk. No issues with the 3rd brakelight on a 95 car which is what I have. I've seen 3.2s running these so no probs.
Cheers,
David
Cheers,
David
What are you going to do? Will your car be registered in Germany? Will you have a TUeV inspection? Formally, a certificate by Porsche exists for the road worthiness of the 3rd brake light, but I doubt any TUeV examiner would be aware of this detail and require you to produce papers as long as they see Porsche serials. Nevertheless, I can send you a pdf copy (German) if you like.
Felix
Thanks Felix, I will let you know if it is necessary. It sounds as though I will be having an inspection performed by US inspectors. It shouldn't be as strict as the TuV inspection. But, I don't want to get pulled over because a police officer notices the infraction.
Thanks for the info!
