Running Lights? Canadians?
#32
That's actually the city lights. Mine is a Canadian car as well with litronics and DRLs are the actual fog lights. Most cars I've seen are like this. Curious would it be simple enough to wire DRL as city lights instead of the fogs (vehicles already equipped with DRL from factory)? Handy for those with turbo s ducts since I know they default to hook up via city lights.
#33
Tried it and it didn't work? I pulled the fog lamp relay out and bridged 30 to 87 , but when I start the car, no lights?
#34
Assuming that to be the case, then fuse #14 (fogs) is good, relay 01 is good, as is relay 31.
Then turn everything off, pull relay 31, and insert the jumper between CE panel slots #3 & #5 ( = relay pins 30 +12V) to #87 ( supply side to fogs).
In most cases, that will turn on the fogs when the key is turned to the 'run' position - will look deeper if that does not work.
Caveat - the CE panel also lists relay #34 as the fog light in USA & Japan - no idea, but not the one to pull if your car is so equipped.
#36
I always carry a two & three spade jumper wire set - the three way will bridge the DME ( 30 to the two 87's), and be a sure test of a questionable relay - I mention this one as it must be removed when the car is turned off, as it leaves the fuel pump energized ---- most others, like the 'DRL' patch stay in place.
#38
I recently upgraded my fogs to true HIDs. Wouldn't mind having them run as DRLs, but have a few questions:
Are the two fog bulbs the only lights on? (no other side or rear plate lights, etc)
What happens when you turn on headlights? Do fogs turn off with high beams? Is fog dash switch basically dead item?
#39
I recently upgraded my fogs to true HIDs. Wouldn't mind having them run as DRLs, but have a few questions: Are the two fog bulbs the only lights on? (no other side or rear plate lights, etc) What happens when you turn on headlights? Do fogs turn off with high beams? Is fog dash switch basically dead item?
When you turn on the headlights, fogs will auto turn off.
The interior fog switch still works, example you can activate when the headlights are on.
