Ramps.
I made a set of simple ramps out of 4x4 pressure treated lumber. They are low enough to fit under the back of the rear quarters. I just back the car on the ramps. It makes it quick and easy to do simple things under the car. It's also easy to jack up the front by bringing the jack in from behind the front wheels. My car sits about euro ride height - 10mm. The cost was about $10 in materials and 30 minutes to construct them. The ramp width of 7" is plenty enough to support the car. I snapped a quick photo.
Thanks all. Since nobody came up with a height dimension, I gues I'll just have to measure things and do the maths!
I am thinking of making some like swmic has. As for the bumper clearance, I guess I can just increase the length of the angled section of the ramp.
I may even go for a "deluxe" version that will allow me to remove the angled section once the car is up on the flat section.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Originally Posted by a17sbn
Thanks Jean-Pierre. I had a look at your post - they are the kind of thing I intend making, but a lot higher.
The "restoration" site is great. Good lateral thinking there.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Hi J-P,
Yes, I realise that higher = longer.
I have been doing some more Googling, and have come up with what may be a good solution. Go to:-
(http://www.northerntooluk.com/produc...lt.asp?id=1564)
Those flat ramps are cheap (c.£50) and I could then simply make a timber block of the desired height to run up on to.
What do you think?
What do you think?
WRT the Restoration Ramps - typical English ingenuity I'd call it!!!! ![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Roger on that.
WRT the other site... did you note the capacity of these ramps?? 225 kgs?? I dont want to work under these.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
J-P, yes I did notice the weight limit. I intend calling them to see if it was a typo - they are called "car ramps" so I would have thought they would handle the weight.
In any event, I wouldn't plan on letting them carry the weight whilst I'm under the car. As I said, I'd just use the ramps to get the wheels up onto some timber blocks.
King of Cool
I may even go for a "deluxe" version that will allow me to remove the angled section once the car is up on the flat section.![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Following hard on the heels of the "English ingenuity", comes some American (or maybe Finnish??) ingenuity.
Smart idea, thanks. Now why didn't I think of that.
Hi Flying Finn,
Having just given your suggestion some more thought, the height of the ramp will be dependent upon the distance between the fulcrum (the centre of the wheel that remains on the ground), and the bottom of the wheel that is on the ramp.
So much for American (or maybe Finnish???) ingenuity!!!!
(Only joking)
Hi guys,
I used "Monique's ramps" (
) under the front of my car to limit the noze down pitch when lifting the rear of the car to get enough clearance with the ground, to be able to pull the engine and tranny out.
![](http://62.210.160.29/2004/Images2/21204/jmroVXKLZ2D14122004222725538933.jpg)
I modified them a bit with 2 small iron bars fitting in holes in my garage's floor. This preventing any forward slipping of the ramps when the rear of the car was lifted.
![](http://62.210.160.29/2004/Images2/21204/jmroVXKLZ2D14122004215152376651.jpg)
The best solution to go under the car is a pit if your roof doesn't allow a lift.
