Turbo bumper cover fitment tricks
Are there any tricks to putting a bumper cover on the 993 painlessly? When I took it off, I remember that it came out at an upward angle and the top had to be "massaged out."
It's now painted and I don't want to damage the paint by monkeying around with it too much.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Yes, I know what you mean. Its tricky to get the upper corners near the headlights to fit into place. Gotta dip one corner in and move it laterally to that side as far as possible. This will help you get the other side into place. Keep an eye on all of the other tabs and fingers that need to be in place at the same time.
Funny how it removes so easily, then when you have to be ginger with the fresh paint, its a little difficult..
Love the avatar BTW...
Chris, that's exactly the issue I'm referring to. Do you mean dip/bend it under the fender and move it laterally for the other end to line up?
I'm glad you like the avatar. I've attached a couple versions I came across for any of you guys that might be interested.
http://flypicture.com/bin/?id=rtv9kKTc
http://flypicture.com/bin/?id=rtv9kKTf
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Are you planning on putting a 3M clearbra to protect the paint? If so, you may want to keep the bumper off for 3-4 weeks and put it out in the sun and let the paint cure....otherwise you will have rock chips on your newly painted bumper before you can clearbra it.
